path: root/include/configs/SBC8560.h
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
2004-07-10* Rename SBC8560 into sbc8560 for consistencywdenk
* Patch by Daniel Poirot, 24 Jun 2004: Add support for Wind River's sbc8240 board * Patches by Yasushi Shoji, 26 Jun 2004: - drivers/serial_xuartlite.c: fix "return 0" in void function - add microblaze support to mkimage tool
2004-07-10* Patch by Fred Klatt, 25 Jun 2004:wdenk
Add support for WindRiver's SBC8560 board * Patch by Nicolas Lacressonniere, 24 Jun 2004 Small Bugs fixes for "at91rm9200dk" board: - Timing modifications for SPI DataFlash access - Fix NAND flash detection bug * Patch by Nicolas Lacressonniere, 24 Jun 2004: Add Support for Flash AT49BV6416 for AT91RM9200DK board
