path: root/include/configs/SBC8540.h
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-17powerpc: cpm2 boards: update fcc register logicMike Frysinger
In the recent dropping of !NET_MULTI code (commit e2a53458a7ab37523304), I misread the logic in include/net.h. Some of it was used by NET_MULTI code as glue between the multi/non-multi worlds for cpm2 boards. Rather than restore the block of code, push the logic to the board config headers where it all belongs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-1485xx boards: Rename CONFIG_DDR_DLL to CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_INBecky Bruce
This config option is for an erratum workaround; rename it to be more clear. Also, drop it from config files don't need it and were undefining it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-10Update all board to support new bbmiiphy driver (with multibus support)Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-24sbc85x0: tidy up Makefile to use new configuration script.Paul Gortmaker
Commit 804d83a5 allows us to move all the configuration variation tweaks out of the top level Makefile and down into the boards config header. This takes advantage of that for the sbc8540/sbc8560 boards. There were a couple of cheezy comments pointing at incorrect files, or files that don't exist, so I've cleaned those up too. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-22ppc: Clean up calling of phy_reset() during initPeter Tyser
Remove board-specific #ifdefs for calling phy_reset() during initializtion Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-08-27FSL DDR: Convert SBC8560 to new DDR code.Kumar Gala
2008-06-11FSL LAW: Keep track of LAW allocationsKumar Gala
Make it so we keep track of which LAWs have allocated and provide a function (set_next_law) which can allocate a LAW for us if one is free. In the future we will move to doing more "dynamic" LAW allocation since the majority of users dont really care about what LAW number they are at. Also, add CONFIG_MPC8540 or CONFIG_MPC8560 to those boards which needed them Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Convert SBC8540/SBC8560/SBC8548 to new TLB setupKumar Gala
2008-01-1685xx: convert SBC8540/SBC8560/SBC8548 over to use new LAW init codeKumar Gala
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2004-12-31* Code cleanup, mostly for GCC-3.3.xwdenk
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for additional ethernet addresses. * Cleanup drivers/i82365.c - avoid duplication of code * Fix bogus "cannot span across banks" flash error message * Add support for CompactFlash for the CPC45 Board.
2004-10-11CleanupLABEL_2004_10_12_0110wdenk
2004-10-10* Patch by Michael Bendzick, 30 Aug 2004:wdenk
- Improve platform.S code for omap1510inn that detects whether code is running from SDRAM or not. Patch allows SDRAM to be configured if code is running out of SRAM at 0x20000000. * Patch by Frederick Klatt, 30 Aug 2004: Add support for the Wind River SBC8540/SBC8560 boards
