path: root/include/configs/Rattler.h
2011-10-17powerpc: cpm2 boards: update fcc register logicMike Frysinger
In the recent dropping of !NET_MULTI code (commit e2a53458a7ab37523304), I misread the logic in include/net.h. Some of it was used by NET_MULTI code as glue between the multi/non-multi worlds for cpm2 boards. Rather than restore the block of code, push the logic to the board config headers where it all belongs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-10-10Update all board to support new bbmiiphy driver (with multibus support)Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-03-20Separate mtdparts command from jffs2Stefan Roese
Currently the mtdparts commands are included in the jffs2 command support. This doesn't make sense anymore since other commands (e.g. UBI) use this infrastructure as well now. This patch separates the mtdparts commands from the jffs2 commands making it possible to only select mtdparts when no JFFS2 support is needed. Signed-off-by: Stefan Roese <sr@denx.de> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com>
2008-02-12Get rid of "#undef DEBUG" from board config files.Wolfgang Denk
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09include/: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
Mostly removed from comments here. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-08include/configs: Use new CONFIG_CMD_* in various R* named board config files.Jon Loeliger
2006-03-12Adjust "echo" as a default commandWolfgang Denk
Patch by Sam Song, 19 Jun 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-07-23* Patch by Jon Loeliger, Kumar Gala 2005-02-08Jon Loeliger
- Convert the CPM2 based functionality to use new CONFIG_CPM2 option rather than a myriad of CONFIG_MPC8560-like variants. Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560. Eliminates the CONFIG_MPC8560 option entirely. Distributes the new CONFIG_CPM2 option to each 8260 board.
2005-05-05Increase CFG_MONITOR_LEN for Rattler board to match actual code size.wdenk
2005-04-03* Patch by Yuli Barcohen, 08 Nov 2004:wdenk
Add support for Analogue & Micro Rattler boards. Tested on Rattler8248. * Patch by Andre Renaud, 08 Nov 2004: Fix watchdog support in common/lcd.c * Patch by Marc Leeman, 05 Nov 2003: Enable all 4 PCMBRW buffers for the MPC8245 processor since the CPU bug only affects the XPC8245 processors
