The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
Since the lcd code was compiled unconditionally in arch also
add CONFIG_MPC8XX_LCD to the boards using this driver.
cc: Anatolij Gustschin <agust@denx.de>
cc: Wolfgang Denk <wd@denx.de>
Signed-off-by: Jeroen Hofstee <jeroen@myspectrum.nl>
move most of mpc8xx hooks from cmd_ide.c into ide_preinit() and newly created
ide_init_postreset() (invoked after calling ide_reset after ide_preinit),
some cleanup to make checkpatch happy, enable IDE init hooks in configs of
affected boards.
confusingly, these hooks are used by more than just mpc8xx-based boards, and
therefore are placed in arch/ppc/lib/
note: checkpatch still emits warnings about using volatile
Signed-off-by: Pavel Herrmann <morpheus.ibis@gmail.com>
We provide a default table of { 9600, 19200, 38400, 57600, 115200 }
in <config_fallbacks.h> which mkconfig places after <configs/...h> in
the generated config file. This is used when a board has not set its
own table.
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
With recent toolchains, the environment sectors were no longer aligned to
sector boundaries. The reason was a combination of two bugs:
1) common/environment.c assumed that CONFIG_TQM8xxL would be defined
for all TQM8xxL and TQM8xxM boards. But "include/common.h", where
this gets defined, is not included here (and cannot be included
without causing lots of problems).
Added a new #define CFG_USE_PPCENV for all boards which really
want to put the environment is a ".ppcenv" section.
2) The linker scripts just include environment.o, silently assuming
that the objects in that file are really in the order in which
they are coded in the C file, i. e. "environment" first, then
"redundand_environment", and "env_size" last. However, current
toolchains (GCC-4.x) reorder the objects, causing the environment
data not to start on a flash sector boundary:
Instead of: we got:
40008000 T environment 40008000 T env_size
4000c000 T redundand_environment 40008004 T redundand_environment
40010000 T env_size 4000c004 T environment
Note: this patch fixes just the first part, and cures the alignment
problem by making sure that "env_size" gets placed correctly. However,
we still have a potential issue because primary and redundant
environment sectors are actually swapped, i. e. we have now:
40008000 T redundand_environment
4000c000 T environment
40010000 T env_size
This shall be fixed in the next version.
CONFIG_BOOTP_MASK.
which makes the environment compatible with the hush shell.
WARNING: Support for the old '$(...)' syntax will be
discontinued in a later version.
- Correct flash and JFFS2 support for MPC8260ADS
- fix PVR values and clock generation for PowerQUICC II family
(8270/8275/8280)
* Patch by Bernhard Kuhn, 08 Jul 2003:
- add support for M68K targets
* Patch by Ken Chou, 3 Jul:
- Fix PCI config table for A3000
- Fix iobase for natsemi.c
(PCI_BASE_ADDRESS_0 is the IO base register for DP83815)
* Allow to enable "slow" POST routines by key press on power-on
* Fix temperature dependend switching of LCD backlight on LWMON
* Tweak output format for LWMON
- remove trailing white space, trailing empty lines, C++ comments, etc.
- split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c)
* Patches by Kenneth Johansson, 25 Jun 2003:
- major rework of command structure
(work done mostly by Michal Cendrowski and Joakim Kristiansen)
instead CFG_MONITOR_LEN is now only used to determine _at_compile_
_time_ (!) if the environment is embedded within the U-Boot image,
or in a separate flash sector.
* Cleanup CFG_DER #defines in config files (wd maintained only)
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
