path: root/include/configs/RPXlite_DW.h
2005-01-22Code cleanup.wdenk
2005-01-10Coding Style cleanupwdenk
2005-01-09* Patch by Sam Song, 11 October 2004:wdenk
- Add RESET/PREBOOT/AUTOBOOT support for RPXlite_DW board - Adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz * Patch by Sam Song, 10 Oct 2004: Fix a parameter error in run_command() in main.c
2004-10-09Patch by Sam Song, 21 August 2004:wdenk
- Fix a typo in README - Align "(RO)" output for "flinfo" after "protect on" - Add RESET support for RPXlite_DW board; adjust CPU:BUS frequency ratio 1:1 when core frequency less than 50MHz
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-06-09Patch by Sam Song, 09 Jun 2004:wdenk
- Add support for RPXlite_DW board - Update FLASH driver for 4*AM29DL323DB90VI - Add option configuration of CFG_ENV_IS_IN_NVRAM on RPXlite_DW board
