path: root/include/configs/RPXlite.h
2006-03-12RPXlite configuration fixesWolfgang Denk
- Use correct flash sector size - Use correct memory test end address - Add support for bzip2 compression - Various small fixes Patch by Yuli Barcohen, 05 Jun 2005
