Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
move VERSION_VARIABLE from board config file into a
Kconfig option.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
This option only complicates the code unnecessarily, just use
CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are
only five arguments to eeprom {read/write} if this is defined.
If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all
six arguments.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
The config option has been removed by one of the syncs with the Linux
mainline MTD subsystem:
ff94bc40af (mtd, ubi, ubifs: resync with Linux-3.14)
It has been left inside the config files. Currently does not look to
serve any purpose, so remove it now from all the configs.
Signed-off-by: Igor Grinberg <grinberg@compulab.co.il>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Stefan Roese <sr@denx.de>
Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
Cc: Peter Barada <peter.barada@logicpd.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
them from include/configs.
This patch moves the following config options to Kconfig:
CONFIG_AUTOBOOT_KEYED
CONFIG_AUTOBOOT_PROMPT
CONFIG_AUTOBOOT_DELAY_STR
CONFIG_AUTOBOOT_STOP_STR
AUTOBOOT_KEYED_CTRLC
[trini: Drop ip04 and pm9263 configs/ additions, those boards previously
set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over
all boards that did change. Make digsy_mtc_* string include seconds to
match others and not warn. ]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
- switch to GENERIC_BOARD
- fix env support from eeprom
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
As ppc4xx currently only supports the deprecated nand_spl infrastructure
and nobody seems to have time / resources to port this over to the newer
SPL infrastructure, lets remove NAND booting completely.
This should not affect the "normal", non NAND-booting ppc4xx platforms
that are currently supported.
Cc: Tirumala Marri <tmarri@apm.com>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Cc: Tom Rini <trini@ti.com>
Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
We do not have to define CONFIG_4xx in board config headers
because it is defined in arch/powerpc/cpu/ppc4xx/config.mk.
include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx".
I believe it is a typo because "CONFIG_4x" is not used at all
in other files.
So, I also deleted "CONFIG_4x" in include/configs/JSE.h.
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Tested-by: Stefan Roese <sr@denx.de>
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Remove any notion of CONFIG_SERIAL_MULTI from board config files.
Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless
to specify this config option in the board config files. Therefore
remove it.
Cc: Marek Vasut <marek.vasut@gmail.com>
Adapt the following patch from spl to nand_spl:
Author: Stefano Babic <sbabic@denx.de>
Date: Thu Dec 15 10:55:37 2011 +0100
nand_spl_simple: store ecc data on the stack
Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM
which is likely to contain already loaded data.
The patch saves the oob data and the ecc on the stack replacing
the fixed address in RAM.
CC: Ilya Yanok <yanok@emcraft.com>
CC: Scott Wood <scottwood@freescale.com>
CC: Tom Rini <tom.rini@gmail.com>
CC: Simon Schwarz <simonschwarzcor@googlemail.com>
CC: Wolfgang Denk <wd@denx.de>
While nand_spl is on its way out, in favor of spl, there are still
many boards using it, and conversions are gradual. This allows us
to get rid of CONFIG_SYS_NAND_ECCSTEPS and CONFIG_SYS_NAND_ECCTOTAL now,
which would otherwise be likely to linger unreferenced after a conversion.
It also eliminates a temporary error in the hawkboard_nand build, since
the spl version of the patch removed ECCSTEPS/TOTAL from hawkboard.h, but
the spl conversion is pending (and may be merged via a different tree).
This patch switches PMC440 board code to the CONFIG_PCI_BOOTDELAY option
instead of using a private implemention. This relies on Anatolji's patch
that moves the pcidelay handling behind pci_target_init.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
include/ppc4xx.h
This patch removes the PPC4xx UART driver. Instead the common NS16550
driver is used, since all PPC4xx SoC's use this peripheral device.
The file 4xx_uart.c now only implements the UART clock calculation
function which also sets the SoC internal UART divisors.
All PPC4xx board config headers are changed to use this common NS16550
driver now.
Tested on these boards:
acadia, canyonlands, katmai, kilauea, sequoia, zeus
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
Update image size and default environment
after addition of new environment handling.
This patch moves the PPC4xx specific I2C device driver into the I2C
drivers directory. All 4xx config headers are updated to include this
driver.
Remove some unused features and default environment variable
to shrink the PMC440 u-boot.
This patch shrinks the PMC440 u-boot binary (from next branch)
to fit into 384kB again.
This patch removes the duplicted implementations of the pci_pre_init()
function by introducing a weak default function for it. This weak default
has a different implementation for some PPC variants. It can be
overridden by a board specific version.
This patch removes the duplicted implementations of the pci_target_init()
has a different implementation for 440EP(x)/GR(x) PPC's. It can be
overridden by a board specific version (e.g. PMC440, korat).
Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
This patch adds support to detect the amount of DDR2 SDRAM
on PMC440 modules. Detection is done by probing through
a list of available and supported hardware configurations
from 1GByte down to 256MB.
The static TLB entry is replaced by dynamically created entries.
