path: root/include/configs/PMC440.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-28configs: remove remnants of CONFIG_SYS_NAND_QUIET_TESTIgor Grinberg
The config option has been removed by one of the syncs with the Linux mainline MTD subsystem: ff94bc40af (mtd, ubi, ubifs: resync with Linux-3.14) It has been left inside the config files. Currently does not look to serve any purpose, so remove it now from all the configs. Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Stefan Roese <sr@denx.de> Cc: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> Cc: Peter Barada <peter.barada@logicpd.com> Cc: Steve Sakoman <sakoman@gmail.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Stefan Roese <sr@denx.de>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-10-27ppc4xx: update PMC440 board supportMatthias Fuchs
- switch to GENERIC_BOARD - fix env support from eeprom Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-03-07ppc4xx: Remove 4xx NAND booting supportStefan Roese
As ppc4xx currently only supports the deprecated nand_spl infrastructure and nobody seems to have time / resources to port this over to the newer SPL infrastructure, lets remove NAND booting completely. This should not affect the "normal", non NAND-booting ppc4xx platforms that are currently supported. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Tirumala Marri <tmarri@apm.com> Cc: Matthias Fuchs <matthias.fuchs@esd.eu> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Tested-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-01-26nand_spl: store ecc data on the stackScott Wood
Adapt the following patch from spl to nand_spl: Author: Stefano Babic <sbabic@denx.de> Date: Thu Dec 15 10:55:37 2011 +0100 nand_spl_simple: store ecc data on the stack Currently nand_spl_simple puts it's temp data at 0x10000 offset in SDRAM which is likely to contain already loaded data. The patch saves the oob data and the ecc on the stack replacing the fixed address in RAM. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Ilya Yanok <yanok@emcraft.com> CC: Scott Wood <scottwood@freescale.com> CC: Tom Rini <tom.rini@gmail.com> CC: Simon Schwarz <simonschwarzcor@googlemail.com> CC: Wolfgang Denk <wd@denx.de> Signed-off-by: Scott Wood <scottwood@freescale.com> While nand_spl is on its way out, in favor of spl, there are still many boards using it, and conversions are gradual. This allows us to get rid of CONFIG_SYS_NAND_ECCSTEPS and CONFIG_SYS_NAND_ECCTOTAL now, which would otherwise be likely to linger unreferenced after a conversion. It also eliminates a temporary error in the hawkboard_nand build, since the spl version of the patch removed ECCSTEPS/TOTAL from hawkboard.h, but the spl conversion is pending (and may be merged via a different tree). Signed-off-by: Scott Wood <scottwood@freescale.com>
2011-12-01ppc4xx: use CONFIG_PCI_BOOTDELAY instead of private implementationMatthias Fuchs
This patch switches PMC440 board code to the CONFIG_PCI_BOOTDELAY option instead of using a private implemention. This relies on Anatolji's patch that moves the pcidelay handling behind pci_target_init. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-08-09ppc4xx: Fix building of PMC440 boardMatthias Fuchs
Update image size and default environment after addition of new environment handling. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2010-02-03ppc4xx: Fix building of PMC440 boardMatthias Fuchs
Remove some unused features and default environment variable to shrink the PMC440 u-boot. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Remove unused features from PMC440 board supportMatthias Fuchs
This patch shrinks the PMC440 u-boot binary (from next branch) to fit into 384kB again. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_pre_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_pre_init() function by introducing a weak default function for it. This weak default has a different implementation for some PPC variants. It can be overridden by a board specific version. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-19ppc4xx: Consolidate pci_target_init() functionStefan Roese
This patch removes the duplicted implementations of the pci_target_init() function by introducing a weak default function for it. This weak default has a different implementation for 440EP(x)/GR(x) PPC's. It can be overridden by a board specific version (e.g. PMC440, korat). Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2009-10-02ppc4xx: Add SDRAM detection for PMC440 boardsMatthias Fuchs
This patch adds support to detect the amount of DDR2 SDRAM on PMC440 modules. Detection is done by probing through a list of available and supported hardware configurations from 1GByte down to 256MB. The static TLB entry is replaced by dynamically created entries. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-12-16Coding style cleanup, update CHANGELOG.Wolfgang Denk
2008-12-14Fix new found CFG_Jean-Christophe PLAGNIOL-VILLARD
Also fix some minor typos. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-31ppc4xx: Update PMC440 board configurationMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
