path: root/include/configs/PM520.h
2006-01-13Fix 28F256J3A support on PM520 boardWolfgang Denk
(without bank-switching only 32 MB can be accessed)
2005-12-29Add support for 28F256J3A flah (=> 64 MB) on PM520 boardWolfgang Denk
2005-10-28Add support for multiple PHYs.Marian Balakowicz
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2004-06-19Patch by Josef Wagner, 04 Jun 2004:wdenk
- DDR Ram support for PM520 (MPC5200) - support for different flash types (PM520) - USB / IDE / CF-Card / DiskOnChip support for PM520 - 8 bit boot rom support for PM520/CE520 - Add auto SDRAM module detection for MicroSys CPC45 board (MPC8245) - I2C and RTC support for CPC45 - support of new flash type (28F160C3T) for CPC45
2004-05-05* Fix config option spelling in PM520 config filewdenk
* Fix PHY discovery problem in cpu/mpc8xx/fec.c (introduced by patches by Pantelis Antoniou, 30 Mar 2004)
2004-03-23* Add start-up delay to make sure power has stabilized beforewdenk
attempting to switch on USB on SX1 board. * Patch by Josef Wagner, 18 Mar 2004: - Add support for MicroSys XM250 board (PXA255) - Add support for MicroSys PM828 board (MPC8280) - Add support for 32 MB Flash on PM825/826 - new SDRAM refresh rate for PM825/PM826 - added support for MicroSys PM520 (MPC5200) - replaced Query by Identify command in CPU86/flash.c to support 28F160F3B * Fix wrap around problem with udelay() on ARM920T * Add support for Macronix flash on TRAB board
