path: root/include/configs/PLU405.h
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-03ppc4xx: Coding style cleanupMatthias Fuchs
Wrap long lines etc. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Enable USB on PLU405 boardsMatthias Fuchs
This patch enables the PCI-OHCI controller on PLU405 board. Also the default CPU frequency is updated to 266 MHz and command line editing is enabled. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Add fdt support for PLU405 boardsMatthias Fuchs
Signed-off-by: Matthias Fuchs <mf@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Increase U-Boot size to 384kB for PLU405 boardsMatthias Fuchs
2008-08-06Fix merge problemsStefan Roese
2007-12-28ppc4xx: Add EEPROM write protection for PLU405 boards + misc. updatesMatthias Fuchs
- add EEPROM write protection for esd PLU405 boards. - initialize NAND GPIOs - use correct io accessors - cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-15NAND: Add CFG_NAND_QUIET optionMatthias Fuchs
This config option sets the default for the progress information output behavior that can also be configured through the 'quiet' environment variable. The legacy NAND code does not print the current progress info on the console. So this option is for backward compatibility for units that are in the field and where setting the quiet variable is not an option. With CFG_NAND_QUIET set to '1' the console progress info is turned off. This can still be overwritten through the environment variable. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Migrate esd 405EP boards to new NAND subsystem -cleanup -use correct io accessors (in/out_be32()) Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2007-03-08fixed ethernet phy configuration for plu405 boardMatthias Fuchs
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-05-03* Patch by Matthias Fuchs, 03 May 2005:stroese
Added missing variable declaration in cmd_nand.c Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
2004-12-16esd config files updatedstroese
2003-09-12New board config file added.stroese
