path: root/include/configs/PLU405.h
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-01-13ppc4xx: switch PLU405 to generic boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Big header cleanup part 2, mostly PPC405 relatedStefan Roese
This cleanup is done by creating header files for all SoC versions and moving the SoC specific defines into these special headers. This way the common header ppc405.h and ppc440.h can be cleaned up finally. As a part from this cleanup, the GPIO definitions for PPC405EP are corrected. The high and low parts of the registers (for example CONFIG_SYS_GPIO0_OSRL vs. CONFIG_SYS_GPIO0_OSRH) have been defined in the wrong order. This patch now fixes this issue by switching these xxxH and xxxL values. This brings the GPIO 405EP port in sync with all other PPC4xx ports. Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-05Merge branch 'master' into nextWolfgang Denk
Conflicts: board/esd/plu405/plu405.c drivers/rtc/ftrtc010.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-11-25ppc4xx: Remove autoupdate feature from PLU405 boardMatthias Fuchs
The autoupdate feature is not used on PLU405 boards. So remove it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-17ppc4xx: Initialize magnetic couplers in PLU405Matthias Fuchs
This patch fixes an ugly behavior of the IL712 magnetic couplers as used on PLU405. These parts will remember their last state over a power cycle which might cause unwanted behavior. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-10ppc4xx: Add UBI support to PLU405 boardsMatthias Fuchs
-add UBI support -increase malloc'able memory size -cleanup MONITOR|FLASH_BASE|LEN constants Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-18NAND: Fix warning Please define CONFIG_SYS_64BIT_VSPRINTF...Wolfgang Denk
Commit 8d2effea added a warning for configurations that use NAND without defining the (then necessary) CONFIG_SYS_64BIT_VSPRINTF but failed to fix the affected boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-26ppc4xx: Remove CONFIG_SYS_IGNORE_405_UART_ERRATA_59 from config filesMatthias Fuchs
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59. Either they define or undef it. Because it's not used in any source files this patch removes any references to it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-03ppc4xx: Coding style cleanupMatthias Fuchs
Wrap long lines etc. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Enable USB on PLU405 boardsMatthias Fuchs
This patch enables the PCI-OHCI controller on PLU405 board. Also the default CPU frequency is updated to 266 MHz and command line editing is enabled. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Add fdt support for PLU405 boardsMatthias Fuchs
Signed-off-by: Matthias Fuchs <mf@esd.eu> Signed-off-by: Stefan Roese <sr@denx.de>
2008-09-03ppc4xx: Increase U-Boot size to 384kB for PLU405 boardsMatthias Fuchs
2008-08-06Fix merge problemsStefan Roese
2007-12-28ppc4xx: Add EEPROM write protection for PLU405 boards + misc. updatesMatthias Fuchs
- add EEPROM write protection for esd PLU405 boards. - initialize NAND GPIOs - use correct io accessors - cleanup Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-15NAND: Add CFG_NAND_QUIET optionMatthias Fuchs
This config option sets the default for the progress information output behavior that can also be configured through the 'quiet' environment variable. The legacy NAND code does not print the current progress info on the console. So this option is for backward compatibility for units that are in the field and where setting the quiet variable is not an option. With CFG_NAND_QUIET set to '1' the console progress info is turned off. This can still be overwritten through the environment variable. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-08-15Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09Migrate esd 405EP boards to new NAND subsystemMatthias Fuchs
Migrate esd 405EP boards to new NAND subsystem -cleanup -use correct io accessors (in/out_be32()) Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2007-03-08fixed ethernet phy configuration for plu405 boardMatthias Fuchs
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-05-03* Patch by Matthias Fuchs, 03 May 2005:stroese
Added missing variable declaration in cmd_nand.c Modified CFG_PCI_PTM1MS in configs/PLU405.h to map 128MB ram
