path: root/include/configs/PK1C20.h
2010-04-02nios2: Set CONFIG_SYS_HZ to 1000 all nios2 boards.Scott McNutt
CONFIG_SYS_HZ was being calculated (incorrectly) in nios2 configuration headers. Updated comments to accurately describe timebase macros. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2010-04-02nios2: Move serial drivers to individual files in drivers/serialScott McNutt
The standard Altera UART & JTAG UART as well as the OpenCores YANU driver are now in individual files in drivers/serial rather than a single file uner cpu/nios2. Signed-off-by: Scott McNutt <smcnutt@psyent.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2006-06-08Update PK1C20 boardScott McNutt
-Update base addresses for standard configuration -Eliminate use of CACHE_BYPASS in board code Patch by Scott McNutt, 08 Jun 2006
2005-03-30* Patch by Scott McNutt, 21 Oct 2004:wdenk
Add support for Nios-II EPCS Controller core. * Patch by Scott McNutt, 20 Oct 2004: Nios-II cleanups: - Add sysid command (Nios-II only). - Locate default exception trampoline at proper offset. - Implement I/O routines (readb, writeb, etc) - Implement do_bootm_linux
2004-10-10Patches by Scott McNutt, 24 Aug 2004:wdenk
- Add support for Altera Nios-II processors. - Add support for Psyent PCI-5441 board. - Add support for Psyent PK1C20 board.
