path: root/include/configs/PIP405.h
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-01-09board/mpl/pip405: use the CFI driver for the PIP405 boardDavid Müller
Signed-off-by: David Mueller <d.mueller@elsoft.ch> Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2009-07-19Merge branch 'master' of git://git.denx.de/u-boot-nand-flashWolfgang Denk
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-17Remove legacy NAND and disk on chip references from boards.Scott Wood
2009-06-12Enable CONFIG_NET_MULTI on all remaining PPC4xx boardsBen Warren
All in-tree PPC4xx boards now use CONFIG_NET_MULTI Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-08ppc4xx: Remove CONFIG_CS8952_PHY defineStefan Roese
Since this define is only used on one board that was never really in production, removing this compile time option doesn't hurt and makes the code more readable. Signed-off-by: Stefan Roese <sr@denx.de>
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2006-03-12Adjust "echo" as a default commandWolfgang Denk
Patch by Sam Song, 19 Jun 2005
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-08-13Fix compiler warningsWolfgang Denk
2003-12-07* Patches by David Müller, 14 Nov 2003:wdenk
- board/mpl/common/common_util.c * implement support for BZIP2 compressed images * various cleanups (printf -> puts, ...) - board/mpl/common/flash.c * report correct errors to upper layers * check the erase fail and VPP low bits in status reg - board/mpl/vcma9/cmd_vcma9.c - board/mpl/vcma9/flash.c * various cleanups (printf -> puts, ...) - common/cmd_usb.c * fix typo in comment - cpu/arm920t/usb_ohci.c * support for S3C2410 is missing in #if line - drivers/cs8900.c * reinit some registers in case of error (cable missing, ...) - fs/fat/fat.c * support for USB/MMC devices is missing in #if line - include/configs/MIP405.h - include/configs/PIP405.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support - include/configs/VCMA9.h * enable BZIP2 support * enlarge malloc space to 1MiB because of BZIP2 support * enable USB support - lib_arm/armlinux.c * change calling convention of ARM Linux kernel as described on http://www.arm.linux.org.uk/developer/booting.php * Patch by Thomas Lange, 14 Nov 2003: Split dbau1x00 into dbau1000, dbau1100 and dbau1500 configs to support all these AMD boards. * Patch by Thomas Lange, 14 Nov 2003: Workaround for mips au1x00 physical memory accesses (the au1x00 uses a 36 bit bus internally and cannot access physical memory directly. Use the uncached SDRAM address instead of the physical one.)
2003-09-10* Patches by Denis Peter, 9 Sep 2003:U-Boot-0_4_8wdenk
add FAT support for IDE, SCSI and USB * Patches by Gleb Natapov, 2 Sep 2003: - cleanup of POST code for unsupported architectures - MPC824x locks way0 of data cache for use as initial RAM; this patch unlocks it after relocation to RAM and invalidates the locked entries. * Patch by Gleb Natapov, 30 Aug 2003: new I2C driver for mpc107 bridge. Now works from flash. * Patch by Dave Ellis, 11 Aug 2003: - JFFS2: fix typo in common/cmd_jffs2.c - JFFS2: fix CFG_JFFS2_SORT_FRAGMENTS option - JFFS2: remove node version 0 warning - JFFS2: accept JFFS2 PADDING nodes - SXNI855T: add AM29LV800 support - SXNI855T: move environment from EEPROM to flash - SXNI855T: boot from JFFS2 in NOR or NAND flash * Patch by Bill Hargen, 11 Aug 2003: fixes for I2C on MPC8240 - fix i2c_write routine - fix iprobe command - eliminates use of global variables, plus dead code, cleanup.
2003-07-24* Implement new mechanism to export U-Boot's functions to standalonewdenk
applications: instead of using (PPC-specific) system calls we now use a jump table; please see doc/README.standalone for details * Patch by Dave Westwood, 24 Jul 2003: added support for Unity OS (a proprietary OS)
2003-06-04* Patch by Denis Peter, 04 June 2003:wdenk
add support for the MIP405T board
2003-04-05* Patch by Arun Dharankar, 4 Apr 2003:LABEL_2003_04_05_0300wdenk
Add IDMA example code (tested on 8260 only) * Add support for Purple Board (MIPS64 5Kc) * Add support for MIPS64 5Kc CPUs * Fix missing setting of "loadaddr" and "bootfile" on ARM and MIPS * Patch by Denis Peter, 04 Apr 2003: - update MIP405-4 board * Patches by Denis Peter, 03 April 2003: - fix PCI IRQs on MPL boards - fix two more un-relocated pointer problems * Fix behaviour of "run" command: - print error message iv variable does not exist - terminate processing of arguments in case of error * Patches by Peter Figuli, 10 Mar 2003 - Add support for BTUART on PXA platform - Add support for WEP EP250 (PXA) board * Fix flash problems on INCA-IP; add tool to allow bruning images to flash using a BDI2000 * Implement fix for I2C Edge Conditions problem for all boards that use the bit-banging driver (common/soft_i2c.c) * Add patches by Robert Schwebel, 31 Mar 2003: - csb226 board: bring in sync with innokom/memsetup.S - csb226 board: fix MDREFR handling - misc doc fixes / extensions - innokom board: cleanup, MDREFR fix in memsetup.S, config update - add BOOT_PROGRESS to armlinux.c
