There was for long time no activity in the 8xx area.
We need to go further and convert to Kconfig, but it
turned out, nobody is interested anymore in 8xx,
so remove it (with a heavy heart, knowing that I remove
here the root of U-Boot).
CONFIG_CMD_IRQ
CONFIG_CMD_IDE
CONFIG_CMD_FDC
CONFIG_CMD_EEPROM
CONFIG_CMD_EEPROM_LAYOUT
CONFIG_EEPROM_LAYOUT_HELP_STRING
[trini: Rework Kconfig logic slightly, define EEPROM location on TI eval
platforms]
Signed-off-by: Chris Packham <judge.packham@gmail.com>
[trini: default y if DM_RTC, re-sync]
CONFIG_CMD_BSP
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
CONFIG_SYS_STDIO_DEREGISTER
This option should never be enabled in SPL, so use
CONFIG_IS_ENABLED(SYS_STDIO_DEREGISTER) when checking the option.
[trini: Re-sync]
CONFIG_USB_KEYBOARD
[trini: Fixup MPC86* configs]
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE
CONFIG_SYS_CONSOLE_ENV_OVERWRITE
CONFIG_CONSOLE_EXTRA_INFO
CONFIG_VIDEO_SW_CURSOR
[trini: Re-convert, find all the cases where this is off]
CONFIG_VGA_AS_SINGLE_DEVICE
Once we migrate to driver model for video, we should be able to drop this
option.
CONFIG_VIDEO_CT69000
CONFIG_CFB_CONSOLE
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
CONFIG_VIDEO
Reviewed-by: Jagan Teki <jteki@openedev.com>
There are a few boards that use CONFIG_ISO_STRING as part of a sanity
check during firmware update at run time. Move this string to Kconfig.
Move the config IDENT_STRING to Kconfig and migrate all boards
[sivadur: Migrate zynq boards]
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
[trini: Update configs, add some default to sunxi Kconfig]
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2
means the autoboot with no delay, with no abort check even if
CONFIG_ZERO_BOOTDELAY_CHECK is defined.
To sum up, the autoboot behaves as follows:
[1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y
autoboot with no delay, but you can abort it by key input
[2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n
autoboot with no delay, with no check for abort
[3] CONFIG_BOOTDELAY=-1
disable autoboot
[4] CONFIG_BOOTDELAY=-2
As you notice, [2] and [4] come to the same result, which means we
do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the
cases only by CONFIG_BOOTDELAY, like this:
[2] CONFIG_BOOTDELAY=-1
disable autoboot
[3] CONFIG_BOOTDELAY=-2
This commit converts the logic as follow:
--> CONFIG_BOOTDELAY=-2
Acked-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Christian Riesch <christian.riesch@omicronenergy.com>
Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
This option currently enables both the command and the SCSI functionality.
Rename the existing option to CONFIG_SCSI since most of the code relates
to the feature.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
This option is mentioned but does not do anything. Drop it.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
them from include/configs.
Signed-off-by: David Müller <d.mueller@elsoft.ch>
We do not have to define CONFIG_4xx in board config headers
because it is defined in arch/powerpc/cpu/ppc4xx/config.mk.
include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx".
I believe it is a typo because "CONFIG_4x" is not used at all
in other files.
So, I also deleted "CONFIG_4x" in include/configs/JSE.h.
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
Cc: Stefan Roese <sr@denx.de>
Tested-by: Stefan Roese <sr@denx.de>
