path: root/include/configs/PCIPPC2.h
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2010-06-23Get rid of bogus CONFIG_SYS_BUS_HZ and CONFIG_SYS_CONFIG_BUS_CLK definitionsWolfgang Denk
CONFIG_SYS_BUS_HZ has not really been used anywhere except to be redined as CONFIG_SYS_BUS_CLK; in addition, the mpc7448hpc2 had the bogus CONFIG_SYS_CONFIG_BUS_CLK setting which duplicated the funtionality. Change all this to use CONFIG_SYS_BUS_CLK consistently. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Frank Gottschling <fgottschling@eltec.de> Cc: Reinhard Arlt <reinhard.arlt@esd-electronics.com> Cc: Eran Man <eran@nbase.co.il> Cc: Stefan Roese <sr@denx.de> Cc: Nye Liu <nyet@zumanetworks.com> Cc: Roy Zang <tie-fei.zang@freescale.com>
2009-07-17Remove legacy NAND and disk on chip references from boards.Scott Wood
2008-08-13drivers/mtd/nand: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
rename CFG_NAND_LEGACY to CONFIG_NAND_LEGACY Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2007-07-09include/configs/[P-S]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2006-03-05Re-factoring the legacy NAND code (legacy NAND now only in board-specificBartlomiej Sieka
code and in SoC code). Boards using the old way have CFG_NAND_LEGACY and BOARDLIBS = drivers/nand_legacy/libnand_legacy.a added. Build breakage for NETTA.ERR and NETTA_ISDN - will go away when the new NAND support is implemented for these boards.
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
