2003-06-27 | * Code cleanup:LABEL_2003_06_27_2340 | wdenk | |
- remove trailing white space, trailing empty lines, C++ comments, etc. - split cmd_boot.c (separate cmd_bdinfo.c and cmd_load.c) * Patches by Kenneth Johansson, 25 Jun 2003: - major rework of command structure (work done mostly by Michal Cendrowski and Joakim Kristiansen) | |||
2003-06-05 | - CFG_RX_ETH_BUFFER added. | stroese | |
2002-11-02 | Initial revision | wdenk | |
