path: root/include/configs/PCI405.h
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-04-06i2c: Move PPC4xx I2C driver into drivers/i2c directoryStefan Roese
This patch moves the PPC4xx specific I2C device driver into the I2C drivers directory. All 4xx config headers are updated to include this driver. Signed-off-by: Stefan Roese <sr@denx.de>
2009-01-26ppc4xx: Remove CONFIG_SYS_IGNORE_405_UART_ERRATA_59 from config filesMatthias Fuchs
Lot's of 405 board config files use CONFIG_SYS_IGNORE_405_UART_ERRATA_59. Either they define or undef it. Because it's not used in any source files this patch removes any references to it. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-25ppc4xx: Remove unused featuresMatthias Fuchs
This patch disables some unused features from the PCI405 configuration to keep U-Boot image size below 192k. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2007-03-14[PATCH] renamed environment variable 'addcon' to 'addcons' for PCI405Matthias Fuchs
boards in terms of unification. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2005-08-12esd PCI405 board updatedStefan Roese
Patch by Matthias Fuchs, 28 Jul 2005
2004-12-16esd config files updatedstroese
2003-09-12Update configuration.stroese
2003-05-23Code cleanup.stroese
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-25esd PCI405 updated.stroese
