path: root/include/configs/PCI405.h
2008-11-25ppc4xx: Remove unused featuresMatthias Fuchs
This patch disables some unused features from the PCI405 configuration to keep U-Boot image size below 192k. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-09Changed PPC4xx EMAC driver to require CONFIG_PPC4xx_EMACBen Warren
All in-tree IBM/AMCC PPC4xx boards using the EMAC get this new CONFIG Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Acked-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-07-10include/configs/[P-Z]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various P* named board config files.Jon Loeliger
2007-03-14[PATCH] renamed environment variable 'addcon' to 'addcons' for PCI405Matthias Fuchs
boards in terms of unification. Signed-off-by: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
2005-08-12esd PCI405 board updatedStefan Roese
Patch by Matthias Fuchs, 28 Jul 2005
2004-12-16esd config files updatedstroese
2003-09-12Update configuration.stroese
2003-05-23Code cleanup.stroese
2003-03-26Make compile clean, fix the usual small problems.LABEL_2003_03_26_1300wdenk
2003-03-25esd PCI405 updated.stroese
