path: root/include/configs/P5040DS.h
2016-11-23powerpc: P5040DS: Remove macro CONFIG_P5040DSYork Sun
Use CONFIG_TARGET_P5040DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P5040: Remove macro CONFIG_P5040York Sun
Replace CONFIG_P5040 with ARCH_P5040 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2014-12-05powerpc/P5040DS: enable SATA supportShaohui Xie
The define CONFIG_FSL_SATA_V2 is missing, so SATA is not available in U-boot. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2012-11-27powerpc/85xx: add support for the Freescale P5040DS Superhydra reference boardTimur Tabi
The P5040DS reference board (a.k.a "Superhydra") is an enhanced version of P3041DS/P5020DS ("Hydra") reference board. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
