path: root/include/configs/P4080DS.h
2013-06-20powerpc/boot: Change the macro of Boot from SRIO and PCIE master moduleLiu Gang
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable the master module of Boot from SRIO and PCIE on a platform. But this is not a silicon feature, it's just a specific booting mode based on the SRIO and PCIE interfaces. So it's inappropriate to put the macro into the file arch/powerpc/include/asm/config_mpc85xx.h. Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to "CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros in configuration header file of each board which can support the master module of Boot from SRIO and PCIE. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/85xx: move SRIO configuration out of corenet_ds.hTimur Tabi
The P5040 does not have SRIO, so don't put the SRIO definitions in corenet_ds.h. They belong in the board-specific header files. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-08-23powerpc/fsl-corenet: remove dead variant symbolsScott Wood
These are not supported as individual build targets, but instead are supported by another target. The dead p4040 defines in particular had bitrotted significantly. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-10-03powerpc/85xx: Refactor some defines out of corenet_ds.hKumar Gala
Move some SoC/board specific defines out of corenet_ds.h and into the corresponding P3041DS/P4080DS/P5020.h. We moved CONFIG_MMC, CONFIG_PCIE3, & CONFIG_FSL_NGPIXIS because the P3060 SoC/reference board does not have these devices and it will share the same board code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/8xxx: Introduce 85xx, 86xx, QorIQ config headersKumar Gala
Add new headers that capture common defines for a given SoC/processor rather than duplicating that information in board config.h and random other places. Eventually this should be handled by Kconfig & defconfigs Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-14powerpc/85xx: Add the workaround for erratum ELBC-A001 (enable on P4080)Kumar Gala
Simultaneous FCM and GPCM or UPM operation may erroneously trigger bus monitor timeout. Set timeout to maximum to avoid. Based on a patch from Lan Chunhe <b25806@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Add the workaround for erratum CPC-A003 (enable on P4080)Kumar Gala
CoreNet Platform Cache single-bit data error scrubbing will cause data corruption. Disable the feature to workaround the issue. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Add the workaround for erratum CPC-A002 (enable on P4080)Kumar Gala
CoreNet Platform Cache single-bit tag error scrubbing will cause tag corruption. Disable the feature to workaround the issue. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14fsl_esdhc: Add the workaround for erratum ESDHC136 (enable on P4080)Roy Zang
False multi-bit ECC errors will be reported by the eSDHC buffer which can trigger a reset request. We disable all ECC error checking on SDHC. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14fsl_esdhc: Add the workaround for erratum ESDHC135 (enable on P4080)Roy Zang
The default value of the SRS, VS18 and VS30 and ADMAS fields in the host controller capabilities register (HOSTCAPBLT) are incorrect. The default of these bits should be zero instead of one. Clear these bits out when we read HOSTCAPBLT. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14fsl_esdhc: Add the workaround for erratum ESDHC111 (enable on P4080)Jerry Huang
Do not issue a manual asynchronous CMD12. Instead, use a (software) synchronous CMD12 or AUTOCMD12 to abort data transfer. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12powerpc/p4080ds: Move ICS refclk define into P4080DS.hKumar Gala
We appear to have different refclk's on the different corenet DS boards so move the define out of the common header. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12powerpc/corenet_ds: Move CONFIG_SYS_TEXT_BASE into corenet_ds.hKumar Gala
CONFIG_SYS_TEXT_BASE setting is common across the 'corenet_ds' board family so move it out of P4080DS.h and into corenet_ds.h Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-01powerpc/p4080: Add support for the P4080DS boardKumar Gala
Add support for the P4080DS board, with the following features: * 36-bit only * Boots from NOR flash * FMAN drivers NOT supported * SPD DDR initialization Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Ashish Kalra <Ashish.Kalra@freescale.com> Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Lan Chunhe-B25806 <b25806@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
