path: root/include/configs/P3041DS.h
2016-11-23powerpc: P3041DS: Remove macro CONFIG_P3041DSYork Sun
Use CONFIG_TARGET_P3041DS instead. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: P3041: Remove macro CONFIG_PPC_P3041York Sun
Replace CONFIG_PPC_P3041 with ARCH_P3041 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2013-06-20powerpc/boot: Change the macro of Boot from SRIO and PCIE master moduleLiu Gang
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable the master module of Boot from SRIO and PCIE on a platform. But this is not a silicon feature, it's just a specific booting mode based on the SRIO and PCIE interfaces. So it's inappropriate to put the macro into the file arch/powerpc/include/asm/config_mpc85xx.h. Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to "CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros in configuration header file of each board which can support the master module of Boot from SRIO and PCIE. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-11-27powerpc/corenet_ds: move SATA config to board configurationZang Roy-R61911
board configuration file is included before asm/config_mpc85xx.h. however, CONFIG_FSL_SATA_V2 is defined in asm/config_mpc85xx.h. it will never take effective in the board configuration file for this kind of code : #ifdef CONFIG_FSL_SATA_V2 ... #endif To solve this problem, move CONFIG_FSL_SATA_V2 to board configuration header file. This patch reverts Timur's commit:3e0529f742e893653848494ffb9f7cd0d91304bf Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-22powerpc/85xx: move SRIO configuration out of corenet_ds.hTimur Tabi
The P5040 does not have SRIO, so don't put the SRIO definitions in corenet_ds.h. They belong in the board-specific header files. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-11-29powerpc/85xx: CONFIG_FSL_SATA_V2 should be defined in config_mpc85xx.hTimur Tabi
Macro CONFIG_FSL_SATA_V2 is defined if the SOC has a V2 Freescale SATA controller, so it should be defined in config_mpc85xx.h instead of the various board header files. So now CONFIG_FSL_SATA_V2 is always defined on the P1013, P1022, P2041, P3041, P5010, and P5020. It was already defined for the P1010 and P1014. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-18powerpc/85xx: Add support for RMan LIODN initializationKumar Gala
This patch is intended to initialize RMan LIODN related registers on P2041, P304S and P5020 SocS. It also adds the "rman@0" child node to qman-portal nodes, adds "fsl,liodn" property to RMan inbound block nodes. Signed-off-by: Minghuan Lian <Minghuan.Lian@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-03powerpc/85xx: Refactor some defines out of corenet_ds.hKumar Gala
Move some SoC/board specific defines out of corenet_ds.h and into the corresponding P3041DS/P4080DS/P5020.h. We moved CONFIG_MMC, CONFIG_PCIE3, & CONFIG_FSL_NGPIXIS because the P3060 SoC/reference board does not have these devices and it will share the same board code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-05-19Minor coding style cleanup.Wolfgang Denk
2011-04-27powerpc: Add P3041DS/P5020DS board support (uses corenet_ds code)Kumar Gala
The P3041DS & P5020DS boards are almost identical (except for the processor in them). Additionally they are based on the P4080DS board design so we use the some board code for all 3 boards. Some ngPIXIS (FPGA) registers where reserved on P4080DS and now have meaning on P3041DS/P5020DS. We utilize some of these for SERDES clock configuration. Additionally, the P3041DS/P5020DS support NAND. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
