path: root/include/configs/P2041RDB.h
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-07-21powerpc/85xx: Increase fdt addressScott Wood
Loading the fdt at 0xc00000 fails if the uncompressed kernel image is greater than 12 MiB, which is quite common with modern kernels and multiplatform defconfigs. Move fdtaddr to 0x1e00000 which is just under the ramdiskaddr on most targets. Signed-off-by: Scott Wood <oss@buserror.net> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Andy Fleming <afleming@gmail.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Paul Gortmaker <paul.gortmaker@windriver.com> Reviewed-by: York Sun <york.sun@nxp.com>
2016-05-03include/configs: Numerous typo fixes: "controler" -> "controller".Robert P. J. Day
2016-01-27secure_boot: include/configs: move definition of CONFIG_CMD_BLOBAneesh Bansal
CONFIG_CMD_BLOB must be defined in case of Secure Boot. It was earlier defined in all config files. The definition has been moved to a common file which is included by all configs. Signed-off-by: Aneesh Bansal <aneesh.bansal@nxp.com> Acked-by: Ruchika Gupta <ruchika.gupta@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-12-15mpc85xx: inhibit qman and bman portals by defaultJeffrey Ladouceur
Not all portals might be managed and therefore visible. Set the isdr register so that the corresponding isr register won't be set. This is required when supporting power management. Signed-off-by: Jeffrey Ladouceur <Jeffrey.Ladouceur@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-15powerpc/p2041rdb: enable generic board configsShaohui Xie
Add following configs in header file: CONFIG_SYS_GENERIC_BOARD CONFIG_DISPLAY_BOARDINFO Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Enable blob command in freescale platformsRuchika Gupta
Enable blob commands for platforms having SEC 4.0 or greater for secure boot scenarios Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-10-16mpc85xx: configs - Add hash command in freescale platformsRuchika Gupta
Enable CAAM in platforms supporting the hardware block. Hash command enabled along with hardware accelerated support for SHA-1 and SHA-256 for platforms which have CAAM block. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16powerpc/srio-pcie-boot: Adjust addresses for SRIO/PCIE bootLiu Gang
The new 768KB u-boot image size requires changes for SRIO/PCIE boot. These addresses need to be updated to appropriate locations. The updated addresses are used to configure the SRIO/PCIE inbound windows for the boot, and they must be aligned with the window size based on the SRIO/PCIE modules requirement. So for the 768KB u-boot image, the inbound window cannot be set with 0xfff40000 base address and 0xc0000 size, it should be extended to 1MB size and the base address can be aligned with the size. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-05-16mpc85xx: configs: remove c=ffe from default environmentKim Phillips
AFAICT, c=ffe does nothing and was a typo from the original commit d17123696c6180ac8b74fbd318bf14652623e982 "powerpc/p4080: Add support for the P4080DS board" and just kept on getting duplicated in subsequently added board config files. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Edward Swarthout <ed.swarthout@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22powerpc/mpc85xx:Update MONITOR_LEN for 768KB u-boot sizePrabhakar Kushwaha
U-boot binary size has been increased from 512KB to 768KB. So update CONFIG_SYS_MONITOR_LEN to reflect the same. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-03-12freescale: pblimage: refactor CONFIG_SYS_FSL_PBL_{PBI, RCW}Masahiro Yamada
Pull out "$(SRCTREE)/" from CONFIG_SYS_FSL_PBL_PBI and CONFIG_SYS_FSL_PBL_RCW and push it into the top Makefile. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: York Sun <yorksun@freescale.com> Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2014-01-21powerpc:Rename CONFIG_PBLRCW_CONFIG & CONFIG_SYS_FSL_PBL_PBIPrabhakar Kushwaha
Rename CONFIG_PBLRCW_CONFIG and CONFIG_PBLRCW_CONFIG. Also add their details in README. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-10-16powerpc: add CONFIG_SECURE_BOOT condition into fsl_secure_boot.hPo Liu
This patch is for board config file not to add CONFIG_SECURE_BOOT condition for include the asm/fsl_secure_boot.h. Signed-off-by: Po Liu <Po.Liu@freescale.com>
2013-09-10powerpc/p2041: fix I2C controller's offsetShaohui Xie
Without this patch, SPD access will fail which leads to DDR init fail. Signed-off-by: Shaohui Xie <Shaohui.Xie@freescale.com> Tested-by: Chris Packham <judge.packham@gmail.com> Acked-by: York Sun <yorksun@freescale.com>
2013-08-09powerpc/corenet: Move CONFIG_FSL_CORENET out of board header fileYork Sun
Move CONFIG_FSL_CORENET define to config_mpc85xx.h. It is not board specific feature and belongs to SoC header. Signed-off-by: York Sun <yorksun@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-20powerpc/boot: Change the macro of Boot from SRIO and PCIE master moduleLiu Gang
Currently, the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" can enable the master module of Boot from SRIO and PCIE on a platform. But this is not a silicon feature, it's just a specific booting mode based on the SRIO and PCIE interfaces. So it's inappropriate to put the macro into the file arch/powerpc/include/asm/config_mpc85xx.h. Change the macro "CONFIG_SYS_FSL_SRIO_PCIE_BOOT_MASTER" to "CONFIG_SRIO_PCIE_BOOT_MASTER", remove them from arch/powerpc/include/asm/config_mpc85xx.h file, and add those macros in configuration header file of each board which can support the master module of Boot from SRIO and PCIE. Signed-off-by: Liu Gang <Gang.Liu@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-01-30powerpc/p2041: set RCW and PBI files for .pbl build or P2041RDBValentin Longchamp
In order to be able to build a u-boot.pbl image, both the CONFIG_PBLPBI_CONFIG and CONFIG_PBLRCW_CONFIG variables have to be defined. This patch sets these two files for the P2041RDB board. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
