path: root/include/configs/P2020DS.h
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-01-30corenet: Disable video on P2020DSAndy Fleming
The P2020DS build had grown too large, and video support isn't enabled in almost any other Freescale board. Disabling it allows us to keep building, and provides options for reenabling it later. Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-08-08powerpc/85xx: improve definition of BR_PHYS_ADDR macroTimur Tabi
The BR_PHYS_ADDR(x) macro was missing parentheses around "x" in the macro definition, so callers had to supply their own parenthesis. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-06powerpc/85xx: minor clean-ups to the P2020DS board header fileTimur Tabi
Remove some unused macros and remove all #undef macros. The RTL8139 network adapter is not shipped with the board nor commonly used, so don't define it by default. The E1000 is still defined. Add 57,600 baud as an option. For some reason, this baud rate is missing from many boards. Signed-off-by: Timur Tabi <timur@freescale.com>
2012-07-06powerpc/85xx: Add USB device-tree fixup for various platformsramneek mehresh
Add USB device-tree fixup for following platforms: MPC8536DS, P1022DS, P1023RDS, P2020COME, P2020DS, P2041RDB, P3060QDS Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2012-02-12sdhc_boot: Introduce CONFIG_FSL_FIXED_MMC_LOCATION optionFabio Estevam
Since commit 97039ab98 (env_mmc: Allow board code to override the environment address) mmc_get_env_addr is a weak-aliased function in common/env_mmc.c The mmc_get_env_addr implementation that exists at board/freescale/common/sdhc_boot.c is meant to be used only for PowerPC boards, but currently it is being used for all platforms that have CONFIG_ENV_IS_IN_MMC defined. Introduce CONFIG_FSL_FIXED_MMC_LOCATION so that the boards that need to use the mmc_get_env_addr version from board/freescale/common/sdhc_boot.c could activate this config option on their board file. This fixes the retrieval of CONFIG_ENV_OFFSET on non-PowerPC boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add default usb mode and phy type to hwconfigRamneek Mehresh
Move to use hwconfig for usb mode & phy type instead of magic 'usb_phy_type' environment variable on the following platforms: MPC8536DS, P1020RDB, P1020RDB-PC, P1010RDB, P2020RDB, P2020RDB-PC, P2020RDB, P3041DS, P4080DS, & P5020DS. Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29powerpc/85xx: Enable eSPI controller & SPI boot support on P2020DSJerry Huang
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Zhao Chenhui <b35336@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-08powerpc/85xx: rename NAND prefixes to CONFIG_SYSMatthew McClintock
renaming 85xx define CONFIG_NAND_OR_PRELIM to CONFIG_SYS_NAND_OR_PRELIM and CONFIG_NAND_BR_PRELIM to CONFIG_SYS_NAND_BR_PRELIM to use the more appropriate CONFIG_SYS prefix as well as be consistent with 83xx. Signed-off-by: Matthew McClintock <msm@freescale.com> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Enable eSDHC boot support on P2020 DSJerry Huang
We implement our own mmc_get_env_addr since the environment variables are written to just after the u-boot image on SDCard, so we must read the MBR to get the start address and code length of the u-boot image, then calculate the address of the env. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Zhao Chenhui <b35336@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Update P2020DS default env settingsLi Yang
Read MAC address from EEPROM. Add hwconfig settings. Modified the default othbootargs to include the cache-sram-size parameter. This parameter is needed as the L2 as SRAM is ON by default in the P2020RDB kernel and used by the Gianfar driver. Also cleanup some of the boot commands. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Zhao Chenhui <b35336@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Add eSDHC support on P2020DSJerry Huang
We enable SDHC_CD and SDHC_WP signals (pin muxed with GPIO8 & GPIO9 respectively). We enable EXT2, FAT, and parition support for both MMC & USB configs. Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com> Signed-off-by: Jin Qing <b24347@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/85xx: Move RESET_VECTOR_ADDRESS into config.hKumar Gala
Rather than defining it config.mk we can set it in config.h and remove config.mk from several boards that don't need it. We mimic what 4xx does and introduce CONFIG_RESET_VECTOR_ADDRESS for config.h to set. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Add SRIO support to P2020DSLi Yang
The P2020 has 2 SRIO ports and they are useable on the P2020 DS board. Enable them using the common SRIO init code. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Rework P2020DS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in P2020DS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20Enable POST memory test for P2020DSYork Sun
Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-26powerpc/p2020ds: Integrated with P2020DS DDR change and enabled hwconfigyork
Enabled SPD Enabled DDR2 Enabled hwconfig Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-26powerpc/p2020: Move INIT_RAM_ADDR physical address higher for 36-bit for P2020DSyork
If 36-bit is enabled, move INIT_RAM_ADDR physical address higher to free lowest 4GB address space. Signed-off-by: York Sun <yorksun@freescale.com>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16Move ICS CLK chip frequency calculation code into a common board libraryKumar Gala
We have several boards that use the same ICS307 CLK chip to drive the System clock and DDR clock. Move the code into a common location so we share it. Convert the P2020DS board as the first to use the new common ICS307 code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Timur Tabi <timur@freescale.com>
2010-04-07p2020ds: add alternate boot bank support using the ngPIXIS FPGATimur Tabi
The Freescale P2020DS board uses a new type of PIXIS FPGA, called the ngPIXIS. The ngPIXIS has one distinct new feature: the values of the on-board switches can be selectively overridden with shadow registers. This feature is used to boot from a different NOR flash bank, instead of having a register dedicated for this purpose. Because the ngPIXIS is so different from the previous PIXIS, a new file is introduced: ngpixis.c. Also update the P2020DS checkboard() function to use the new macros defined in the header file. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-03-1285xx: Drop FIT support to allow u-boot image to fit in 512kKumar Gala
The 36-bit build exceeds the 512k size we have. Removing FIT type image support allows us to fit and we dont really use it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Remove CONFIG_SYS_DDR_TLB_STARTKumar Gala
Now that we dynamically determine TLB CAM entries to use we dont need CONFIG_SYS_DDR_TLB_START anymore. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-09-24ppc/85xx: Simplify the top makefile for 36-bit config for P2020DSKumar Gala
2009-09-15ppc/85xx: Enable usb ehci support for p2020ds boardRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-1085xx: Removed BEDBUG support from FSL 85xx boardsKumar Gala
For some reason the MPC8544 enabled BEDBUG if PCI was enabled and that got copied int the MPC8536, MPC8572 and P2020 DS boards. The BEDBUG support has never been made to work completely on e500/85xx so we just disable it to save space and match the other FSL 85xx boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Report which "bank" of NOR flash we are booting from on FSL boardsKumar Gala
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of swizzling the upper address bits of the NOR flash we boot out of which creates the concept of "virtual" banks. This is useful in that we can flash a test of image of u-boot and reset to one of the virtual banks while still maintaining a working image in "bank 0". The PIXIS FPGA exposes registers on LBC which we can use to determine which "bank" we are booting out of (as well as setting which bank to boot out of). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-20Remove last remanants of unused CONFIG_I2C_CMD_TREEPeter Tyser
