path: root/include/configs/P2020DS.h
2010-04-07p2020ds: add alternate boot bank support using the ngPIXIS FPGATimur Tabi
The Freescale P2020DS board uses a new type of PIXIS FPGA, called the ngPIXIS. The ngPIXIS has one distinct new feature: the values of the on-board switches can be selectively overridden with shadow registers. This feature is used to boot from a different NOR flash bank, instead of having a register dedicated for this purpose. Because the ngPIXIS is so different from the previous PIXIS, a new file is introduced: ngpixis.c. Also update the P2020DS checkboard() function to use the new macros defined in the header file. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-03-1285xx: Drop FIT support to allow u-boot image to fit in 512kKumar Gala
The 36-bit build exceeds the 512k size we have. Removing FIT type image support allows us to fit and we dont really use it. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05ppc/85xx: Remove CONFIG_SYS_DDR_TLB_STARTKumar Gala
Now that we dynamically determine TLB CAM entries to use we dont need CONFIG_SYS_DDR_TLB_START anymore. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-09-24ppc/85xx: Simplify the top makefile for 36-bit config for P2020DSKumar Gala
2009-09-15ppc/85xx: Enable usb ehci support for p2020ds boardRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-288xxx: Removed CONFIG_NUM_CPUS from 85xx/86xxPoonam Aggrwal
The number of CPUs are getting detected dynamically by checking the processor SVR value. Also removed CONFIG_NUM_CPUS references from all the platforms with 85xx/86xx processors. This can help to use the same u-boot image across the platforms. Also revamped and corrected few Freescale Copyright messages. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-1085xx: Removed BEDBUG support from FSL 85xx boardsKumar Gala
For some reason the MPC8544 enabled BEDBUG if PCI was enabled and that got copied int the MPC8536, MPC8572 and P2020 DS boards. The BEDBUG support has never been made to work completely on e500/85xx so we just disable it to save space and match the other FSL 85xx boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Report which "bank" of NOR flash we are booting from on FSL boardsKumar Gala
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of swizzling the upper address bits of the NOR flash we boot out of which creates the concept of "virtual" banks. This is useful in that we can flash a test of image of u-boot and reset to one of the virtual banks while still maintaining a working image in "bank 0". The PIXIS FPGA exposes registers on LBC which we can use to determine which "bank" we are booting out of (as well as setting which bank to boot out of). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-20Remove last remanants of unused CONFIG_I2C_CMD_TREEPeter Tyser
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-07Coding style cleanup; update CHANGELOGWolfgang Denk
2009-06-3085xx: Add pci e1000 Ethernet support for P2020 boardRoy Zang
2009-06-308xxx: Fix PCI bus address setup for 36-bit configsKumar Gala
We want the outbound PCI memory map to end at the 4G boundary so we can maximize the amount of space available for inbound mappings if we have large amounts of memory. This matches the device tree setup in the kernel for the 36-bit physical configs for the platforms that have one (MPC8641 HPCN & MPC8572 DS). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add P2020DS supportSrikanth Srinivasan
The patch adds support for P2020DS reference platform. DDR3 interface uses hard-coded initialization rather than SPD for now and was tested at 667Mhz. Some PIXIS register definitions and associated code sections need to be fixed. TSEC1/2/3, NOR flash, MAC/SYS ID EEPROM, PCIE1/2/3 are all tested under u-boot. Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com> Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
