We have several boards that use the same ICS307 CLK chip to drive the
System clock and DDR clock. Move the code into a common location so we
share it.
Convert the P2020DS board as the first to use the new common ICS307
code.
Acked-by: Timur Tabi <timur@freescale.com>
The Freescale P2020DS board uses a new type of PIXIS FPGA, called the ngPIXIS.
The ngPIXIS has one distinct new feature: the values of the on-board switches
can be selectively overridden with shadow registers. This feature is used to
boot from a different NOR flash bank, instead of having a register dedicated
for this purpose. Because the ngPIXIS is so different from the previous PIXIS,
a new file is introduced: ngpixis.c.
Also update the P2020DS checkboard() function to use the new macros defined
in the header file.
The 36-bit build exceeds the 512k size we have. Removing FIT type image
support allows us to fit and we dont really use it.
Now that we dynamically determine TLB CAM entries to use we dont need
CONFIG_SYS_DDR_TLB_START anymore.
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
A bunch of the 85xx boards have this cruft in them - it's not used
anywhere. Delete it.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
The number of CPUs are getting detected dynamically by checking the
processor SVR value. Also removed CONFIG_NUM_CPUS references from all
the platforms with 85xx/86xx processors.
This can help to use the same u-boot image across the platforms.
Also revamped and corrected few Freescale Copyright messages.
Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com>
For some reason the MPC8544 enabled BEDBUG if PCI was enabled and that
got copied int the MPC8536, MPC8572 and P2020 DS boards. The BEDBUG
support has never been made to work completely on e500/85xx so we
just disable it to save space and match the other FSL 85xx boards.
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of
swizzling the upper address bits of the NOR flash we boot out of which
creates the concept of "virtual" banks. This is useful in that we can
flash a test of image of u-boot and reset to one of the virtual banks
while still maintaining a working image in "bank 0".
The PIXIS FPGA exposes registers on LBC which we can use to determine
which "bank" we are booting out of (as well as setting which bank to
boot out of).
We have always mapped at least 16M in the kernel and we have seen cases
with new kernel features that a kernel image needs more than 8M of
memory.
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet
driver, but the code that used that macro was removed over a year
ago, so board configuration files no longer need to define it.
The _IO_BASE macro is also automatically defined to 0 if it isn't
already set, so there's no need to define that macro either in the
board configuration files.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Acked-by: Andy Fleming <afleming@freescale.com>
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
We want the outbound PCI memory map to end at the 4G boundary so we
can maximize the amount of space available for inbound mappings if
we have large amounts of memory.
This matches the device tree setup in the kernel for the 36-bit physical
configs for the platforms that have one (MPC8641 HPCN & MPC8572 DS).
The patch adds support for P2020DS reference platform.
DDR3 interface uses hard-coded initialization rather than SPD
for now and was tested at 667Mhz. Some PIXIS register
definitions and associated code sections need to be fixed.
TSEC1/2/3, NOR flash, MAC/SYS ID EEPROM, PCIE1/2/3 are all
tested under u-boot.
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Travis Wheatley <Travis.Wheatley@freescale.com>
