path: root/include/configs/P1_P2_RDB.h
2010-11-12p1_p2_rdb: to set SQW/INT pin of RTC as INT linePriyanka Jain
SQW/INT pin in RTC can be used for generating square wave(by default) or as interrupt line. U-boot is registering this pin for interrupts. Configuring SQW/INT bit as interrupt line during board initialization to avoid spurious interrupts generated by square wave. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12powerpc/85xx: add CONFIG_SYS_TEXT_BASE_SPL for 85xx nand spl buildHaiying Wang
Introduce a SPL specific CONFIG_SYS_TEXT_BASE_SPL define to be used by the linker. This has similiar semantics to CONFIG_SYS_TEXT_BASE however since SPL is a unqiue image we introduce a new variable to control its text base address. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1685xx/p1_p2_rdb: PCIe E1000 card support added.Poonam Aggrwal
Enables the Intel Pro/1000 PT Gb Ethernet PCI-E Network Adapter configuration support for P1/P2 RDB. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1685xx/p1_p2_rdb: enable hwconfigPoonam Aggrwal
Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-06-29tsec: Fix eTSEC2 link problem on P2020RDBFelix Radensky
On P2020RDB eTSEC2 is connected to Vitesse VSC8221 PHY via SGMII. Current TBI PHY settings for SGMII mode cause link problems on this platform, link never comes up. Fix this by making TBI PHY settings configurable and add a working configuration for P2020RDB. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Acked-by: Andy Fleming <afleming@freescale.com>
2010-06-2985xx/p1_p2_rdb: not able to modify "$bootfile" environment variablePoonam Aggrwal
Because the variable was getting defined twice. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2010-04-07ppc/85xx: Use CONFIG_NS16550_MIN_FUNCTIONS to reduce NAND_SPL sizeKumar Gala
The MPC8536DS_NAND SPL build was failing due to code size increase introduced by commit: commit 33f57bd553edf29dffef5a6c7d76e169c79a6049 Author: Kumar Gala <galak@kernel.crashing.org> Date: Fri Mar 26 15:14:43 2010 -0500 85xx: Fix enabling of L1 cache parity on secondary cores We built in some NS16550 functions that we dont need and can get rid of them via CONFIG_NS16550_MIN_FUNCTIONS. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-2585xx/p1_p2_rdb: enable hwconfigVivek Mahajan
2010-01-05ppc/85xx: Remove CONFIG_SYS_DDR_TLB_STARTKumar Gala
Now that we dynamically determine TLB CAM entries to use we dont need CONFIG_SYS_DDR_TLB_START anymore. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-28Coding Style cleanup; update CHANGELOG, prepare -rc1v2009.11-rc1Wolfgang Denk
2009-10-16ppc/P1_P2_RDB: On-chip BootROM supportDipen Dudhat
On Chip BootROM support for P1 and P2 series RDB platforms. This patch is derived from latest On Chip BootROM support on MPC8536DS Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-16ppc/P1_P2_RDB: NAND Boot SupportDipen Dudhat
NAND Boot support for P1 and P2 series RDB platforms. This patch is derived from NAND Boot support on MPC8536DS. Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-24ppc/85xx: Simplify the top makefile for P1_P2_RDB boardsKumar Gala
2009-08-2885xx: Added PCIe support for P1 P2 RDBPoonam Aggrwal
Call fsl_pci_init_port() to initialize all the PCIe ports on the board. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Removed BEDBUG support on P1_P2_RDBKumar Gala
To match all other 85xx platforms we are removing BEDBUG support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Add support for P2020RDB boardPoonam Aggrwal
The code base adds P1 & P2 RDB platforms support. The folder and file names can cater to future SOCs of P1/P2 family. P1 & P2 processors are 85xx platforms, part of Freescale QorIQ series. Tested following on P2020RDB: 1. eTSECs 2. DDR, NAND, NOR, I2C. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
