path: root/include/configs/P1023RDS.h
2014-02-25kbuild: Move linker sciript check to prepare1Masahiro Yamada
Same as the previous commit. Move sanity check to prepare1 target to avoid nasty troubles. Before this commit, LDSCRIPT existence was not checked when it was specified by CONFIG_SYS_LDSCRIPT. Now LDSCRIPT existence is checked for all boards. $(wildcard $(LDSCRIPT)) must point to the linker scripts with absolute path. Otherwise, make will terminate with a false error on out-of-tree build. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-02-19configs: Delete obsolete macro, CONFIG_SYS_GBL_DATA_SIZEMasahiro Yamada
CONFIG_SYS_GBL_DATA_SIZE is not used any more. The size of struct "global_data" is automatically calculated by asm-offsets. (See lib/asm-offsets.c) GENERATED_GBL_DATA_SIZE should be used instead of CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-21powerpc/mpc85xx:Increase binary size for P, B & T series boards.Prabhakar Kushwaha
u-boot binary size for Freescale mpc85xx platforms is 512KB. This has been reached to upper limit for some of the platforms causig linker error. So, Increase the u-boot binary size to 768KB. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-11-27powerpc/qoriq: Move FMAN microcode locationYork Sun
Move FMAN microcude from 0xEF000000 to 0xEFF40000 to free up the beginning of this virtual bank so that this bank can store RCW or be used together with other banks to store large images. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-07-06powerpc/85xx: Add USB device-tree fixup for various platformsramneek mehresh
Add USB device-tree fixup for following platforms: MPC8536DS, P1022DS, P1023RDS, P2020COME, P2020DS, P2041RDB, P3060QDS Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_STRTOULTom Rini
This define does not control anything, remove it. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15include/configs: Remove CONFIG_SYS_64BIT_VSPRINTFTom Rini
2011-11-29powerpc/85xx: clean up and document the QE/FMAN microcode macrosTimur Tabi
Several macros are used to identify and locate the microcode binary image that U-boot needs to upload to the QE or Fman. Both the QE and the Fman use the QE Firmware binary format to package their respective microcode data, which is why the same macros are used for both. A given SOC will only have a QE or an Fman, so this is safe. Unfortunately, the current macro definition and usage has inconsistencies. For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address of NAND. There's no way to know by looking at a variable how it's supposed to be used. In the future, the code which uploads QE firmware and Fman firmware will be merged. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: Add networking support to P1023RDSRoy Zang
The P1023 has two 1G ethernet controllers the first can run in SGMII, RGMII, or RMII. The second can only do SGMII & RGMII. We need to setup a for SoC & board registers based on our various configuration for ethernet to function properly on the board. Removed CONFIG_SYS_FMAN_FW as its not used anywhere. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: Ioana Radulescu <ruxandra.radulescu@freescale.com> Signed-off-by: Shaohui Xie <b21989@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-29powerpc/85xx: Fix build failure for P1023RDSKumar Gala
When we added the fman fdt fixup we forgot to fixup the P1023RDS platform. So we would get: fdt.c: In function 'fdt_fixup_fman_firmware': fdt.c:465:15: error: 'CONFIG_SYS_FMAN_FW_LENGTH' undeclared (first use in this function) fdt.c:465:15: note: each undeclared identifier is reported only once for each function it appears in Add the needed #defines in P1023RDS.h to fix this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-11powerpc/85xx: Add basic support for P1023RDS boardRoy Zang
The P1023RDS board is the reference board for the P1023 SoC. Add support for booting it from NOR or NAND, with fixed 2G of DDR, PCIe, UART, I2C, etc. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Chunhe Lan <Chunhe.Lan@freescale.com> Signed-off-by: Lei Xu <B33228@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
