path: root/include/configs/P1010RDB.h
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12sdhc_boot: Introduce CONFIG_FSL_FIXED_MMC_LOCATION optionFabio Estevam
Since commit 97039ab98 (env_mmc: Allow board code to override the environment address) mmc_get_env_addr is a weak-aliased function in common/env_mmc.c The mmc_get_env_addr implementation that exists at board/freescale/common/sdhc_boot.c is meant to be used only for PowerPC boards, but currently it is being used for all platforms that have CONFIG_ENV_IS_IN_MMC defined. Introduce CONFIG_FSL_FIXED_MMC_LOCATION so that the boards that need to use the mmc_get_env_addr version from board/freescale/common/sdhc_boot.c could activate this config option on their board file. This fixes the retrieval of CONFIG_ENV_OFFSET on non-PowerPC boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-03powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASHRuchika Gupta
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Kuldip Giroh <kuldip.giroh@freescale.com>
2011-09-29powerpc/85xx: Add NAND/NAND_SPL support to P1010RDBDipen Dudhat
And various defines to enable NAND support and NAND spl code for the P1010RDB platform. Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Add basic support for P1010RDBPoonam Aggrwal
Boot methods supported: NOR Flash, SPI Flash and SDCARD This patch adds the following basic interfaces: DDR3, eTSEC, DUART, I2C, SD/MMC, USB, SATA, PCIe, NOR Flash, SPI Flash. P1010RDB Overview ----------------- 1Gbyte DDR3 (on board DDR) Local Bus (IFC): 32Mbyte 16bit NOR flash 32Mbyte SLC NAND Flash 64KB CPLD device(GPCM interface) SPI Flash: 128 Mbit SPI Flash memory SD/MMC: connector to interface with the SD memory card SATA: 1 internal SATA connect to 2.5. 160G SATA2 HDD 1 eSATA connector to rear panel USB 2.0: x1 USB 2.0 port: connected via a UTMI PHY to Mini-AB interface. x1 USB 2.0 port: directly connected to Mini-AB interface Ethernet eTSEC: eTSEC1: Connected to RGMII PHY VSC8641XKO eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY VSC8221 eCAN: Two DB-9 female connectors for Field bus interface UART: supports two UARTs up to 115200 bps for console TDM: 2 FXS ports connected via an external SLIC to the TDM interface. SLIC: SPI SLIC I2C: Serial EEprom Real time clock 256 Kbit M24256 I2C EEPROM PCIe: PCIe and mPCIe connectors. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
