path: root/include/configs/P1010RDB.h
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-20board/p1010rdb:Add NAND boot support using new SPL formatPrabhakar Kushwaha
- defines constants - Add spl_minimal.c to initialise DDR - update TLB entries as per NAND boot - remove nand_spl support for P1010RDB Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-20powerpc/mpc85xx:No NOR boot, do not compile IFC errata A003399Prabhakar Kushwaha
IFC errata A003399 is valid for IFC NOR boot i.e.if no on-board NOR flash or no NOR boot, do not compile its workaround. Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-11-27powerpc/corenet_ds: move SATA config to board configurationZang Roy-R61911
board configuration file is included before asm/config_mpc85xx.h. however, CONFIG_FSL_SATA_V2 is defined in asm/config_mpc85xx.h. it will never take effective in the board configuration file for this kind of code : #ifdef CONFIG_FSL_SATA_V2 ... #endif To solve this problem, move CONFIG_FSL_SATA_V2 to board configuration header file. This patch reverts Timur's commit:3e0529f742e893653848494ffb9f7cd0d91304bf Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-04-24powerpc/mpc8xxx: Fix CONFIG_DDR_RAW_TIMING for two boardsYork Sun
P1010RDB and p1_pc_rdb_pc has incorrect configuration for CONFIG_DDR_RAW_TIMING. It should be CONFIG_SYS_DDR_RAW_TIMING. Incorrect setting causes DDR failure in case of SPD absent. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2012-02-12sdhc_boot: Introduce CONFIG_FSL_FIXED_MMC_LOCATION optionFabio Estevam
Since commit 97039ab98 (env_mmc: Allow board code to override the environment address) mmc_get_env_addr is a weak-aliased function in common/env_mmc.c The mmc_get_env_addr implementation that exists at board/freescale/common/sdhc_boot.c is meant to be used only for PowerPC boards, but currently it is being used for all platforms that have CONFIG_ENV_IS_IN_MMC defined. Introduce CONFIG_FSL_FIXED_MMC_LOCATION so that the boards that need to use the mmc_get_env_addr version from board/freescale/common/sdhc_boot.c could activate this config option on their board file. This fixes the retrieval of CONFIG_ENV_OFFSET on non-PowerPC boards. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-03powerpc/85xx: Add Secure Boot support on P1010RDB for NOR, NAND & SPIFLASHRuchika Gupta
Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Kuldip Giroh <kuldip.giroh@freescale.com>
2011-09-29powerpc/85xx: Add NAND/NAND_SPL support to P1010RDBDipen Dudhat
And various defines to enable NAND support and NAND spl code for the P1010RDB platform. Signed-off-by: Dipen Dudhat <Dipen.Dudhat@freescale.com> Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: Add basic support for P1010RDBPoonam Aggrwal
Boot methods supported: NOR Flash, SPI Flash and SDCARD This patch adds the following basic interfaces: DDR3, eTSEC, DUART, I2C, SD/MMC, USB, SATA, PCIe, NOR Flash, SPI Flash. P1010RDB Overview ----------------- 1Gbyte DDR3 (on board DDR) Local Bus (IFC): 32Mbyte 16bit NOR flash 32Mbyte SLC NAND Flash 64KB CPLD device(GPCM interface) SPI Flash: 128 Mbit SPI Flash memory SD/MMC: connector to interface with the SD memory card SATA: 1 internal SATA connect to 2.5. 160G SATA2 HDD 1 eSATA connector to rear panel USB 2.0: x1 USB 2.0 port: connected via a UTMI PHY to Mini-AB interface. x1 USB 2.0 port: directly connected to Mini-AB interface Ethernet eTSEC: eTSEC1: Connected to RGMII PHY VSC8641XKO eTSEC2: Connected to SGMII PHY VSC8221 eTSEC3: Connected to SGMII PHY VSC8221 eCAN: Two DB-9 female connectors for Field bus interface UART: supports two UARTs up to 115200 bps for console TDM: 2 FXS ports connected via an external SLIC to the TDM interface. SLIC: SPI SLIC I2C: Serial EEprom Real time clock 256 Kbit M24256 I2C EEPROM PCIe: PCIe and mPCIe connectors. Signed-off-by: Poonam Aggrwal <poonam.aggrwal@freescale.com> Signed-off-by: Dipen Dudhat <dipen.dudhat@freescale.com> Signed-off-by: Prabhakar Kushwaha <prabhakar@freescale.com> Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com> Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
