path: root/include/configs/OXC.h
2004-04-08* Patch by Mark Jonas: Remove config.tmp files only whenwdenk
unconfiguring the board * Adapt RMU board for bigger flash memory * Test fix for ethernet problems on MPC5200
2003-06-05- CFG_RX_ETH_BUFFER added.stroese
