path: root/include/configs/MVS1.h
2007-07-09include/configs/[H-N]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-08include/configs: Use new CONFIG_CMD_* in various M* named board config files.Jon Loeliger
