path: root/include/configs/MVBLM7.h
2014-10-10powerpc: mpc83xx: remove board support for MERGERBOX and MVBLM7Masahiro Yamada
These boards have been orphaned for more than 6 months. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-05-20fpga: Guard the LOADMK functionality with CMD_FPGA_LOADMKSiva Durga Prasad Paladugu
Guard the LOADMK functionality with config to provide an option to enable or disable it. Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-28lib: rand: introduce new configs: CONFIG_LIB_RAND and CONFIG_LIB_HW_RANDPrzemyslaw Marczak
New configs: - CONFIG_LIB_RAND - to enable implementation of rand library in lib/rand.c - CONFIG_LIB_HW_RAND - to enable hardware based implementations of lib rand Other changes: - add CONFIG_LIB_RAND to boards configs which needs rand() - put only one rand.o dependency in lib/Makefile CONFIG_LIB_HW_RAND should be defined for drivers which implements rand library (declared in include/common.h): - void srand(unsigned int seed) - unsigned int rand(void) - unsigned int rand_r(unsigned int *seedp) Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Cc: Michael Walle <michael@walle.cc> Cc: Tom Rini <trini@ti.com> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-24powerpc: mpc83xx: remove redundant CONFIG_MPC83xx definitionMasahiro Yamada
We do not have to define CONFIG_MPC83xx in board config headers because it is defined in arch/powerpc/cpu/mpc83xx/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2013-05-06fpga: Remove all CONFIG_SYS_* fpga related optionsMichal Simek
All these macros are completely unused by any code. CONFIG_FPGA is not a bitfield anymore. Signed-off-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-11-03mpc83xx: Cleanup usage of LBC constantsJoe Hershberger
Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2011-11-03mpc83xx: Cleanup usage of DDR constantsJoe Hershberger
2011-11-03mpc83xx: Cleanup usage of BAT constantsJoe Hershberger
2011-11-03mpc83xx: cosmetic: MVBLM7.h checkpatch complianceJoe Hershberger
2010-10-23MVBLM7: make TSEC2 work again.Andre Schwarz
SICRH has been misconfigured, i.e. TSEC2 clock + D[0:3] are GPIOs. Fix this to be RGMII signals again. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2010-09-23e300: increase CONFIG_SYS_BOOTMAPSZ to allow booting large kernelsIra W. Snyder
Newer Linux kernels can overrun the initial memory window used for booting with their BSS area. When this happens, they overwrite the FDT and silently fail to boot. On e300 CPUs, the Linux kernel uses an initial BAT covering the first 256MB of RAM. See arch/powerpc/kernel/head_32.S for details. Increase the value of CONFIG_SYS_BOOTMAPSZ to accommodate the maximum value allowed by Linux. This will allow very large kernels to boot. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-05-07mpc83xx/mvBLM7: add usb commands and cleanup.Andre Schwarz
Add USB commands. Rename autoscript to bootscript. Add automatic bootscript image generation to makefile. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-22mpc83xx: turn on icache in core initialization to improve u-boot boot timeKim Phillips
before, MPC8349ITX boots u-boot in 4.3sec: column1 is elapsed time since first message column2 is elapsed time since previous message column3 is the message 0.000 0.000: U-Boot 2010.03-00126-gfd4e49c (Apr 11 2010 - 17:25:29) MPC83XX 0.000 0.000: 0.000 0.000: Reset Status: 0.000 0.000: 0.032 0.032: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.032 0.000: Board: Freescale MPC8349E-mITX 0.032 0.000: UPMA: Configured for compact flash 0.032 0.000: I2C: ready 0.061 0.028: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 1.516 1.456: FLASH: 16 MB 2.641 1.125: PCI: Bus Dev VenId DevId Class Int 2.652 0.011: 00 10 1095 3114 0180 00 2.652 0.000: PCI: Bus Dev VenId DevId Class Int 2.652 0.000: In: serial 2.652 0.000: Out: serial 2.652 0.000: Err: serial 2.682 0.030: Board revision: 1.0 (PCF8475A) 3.080 0.398: Net: TSEC1: No support for PHY id ffffffff; assuming generic 3.080 0.000: TSEC0, TSEC1 4.300 1.219: IDE: Bus 0: .** Timeout ** after, MPC8349ITX boots u-boot in 3.0sec: 0.010 0.010: U-Boot 2010.03-00127-g4b468cc-dirty (Apr 11 2010 - 17:47:29) MPC83XX 0.010 0.000: 0.010 0.000: Reset Status: 0.010 0.000: 0.017 0.007: CPU: e300c1, MPC8349E, Rev: 1.1 at 533.333 MHz, CSB: 266.667 MHz 0.017 0.000: Board: Freescale MPC8349E-mITX 0.038 0.020: UPMA: Configured for compact flash 0.038 0.000: I2C: ready 0.038 0.000: DRAM: 256 MB (DDR1, 64-bit, ECC off, 266.667 MHz) 0.260 0.222: FLASH: 16 MB 1.390 1.130: PCI: Bus Dev VenId DevId Class Int 1.390 0.000: 00 10 1095 3114 0180 00 1.390 0.000: PCI: Bus Dev VenId DevId Class Int 1.400 0.010: In: serial 1.400 0.000: Out: serial 1.400 0.000: Err: serial 1.400 0.000: Board revision: 1.0 (PCF8475A) 1.832 0.432: Net: TSEC1: No support for PHY id ffffffff; assuming generic 1.832 0.000: TSEC0, TSEC1 3.038 1.205: IDE: Bus 0: .** Timeout ** also tested on these boards (albeit with a less accurate boottime measurement method): seconds: before after 8349MDS ~2.6 ~2.2 8360MDS ~2.8 ~2.6 8313RDB ~2.5 ~2.3 #nand boot 837xRDB ~3.1 ~2.3 also tested on an 8323ERDB. v2: also remove the delayed icache enablement assumption in arch ppc's board.c, and add a CONFIG_MPC83xx define in the ITX config file for consistency (even though it was already being defined in 83xx' config.mk). Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-04-22mpc83xx: enable command line autocompletionKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-09-26mpc83xx: retain POR values of non-configured ACR, SPCR, SCCR, and LCRR bitfieldsKim Phillips
some LCRR bits are not documented throughout the 83xx family RMs. New board porters copying similar board configurations might omit setting e.g., DBYP since it was not documented in their SoC's RM. Prevent them bricking their board by retaining power on reset values in bit fields that the board porter doesn't explicitly configure via CONFIG_SYS_<registername>_<bitfield> assignments in the board config file. also move LCRR assignment to cpu_init_r[am] to help ensure no transactions are being executed via the local bus while CLKDIV is being modified. also start to use i/o accessors. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-09-22Remove deprecated 'autoscr' command/variablesPeter Tyser
The more standard 'source' command provides identical functionality to the autoscr command. Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'. The 'autoscript' and 'autoscript_uname' environment variables are also removed. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Heiko Schocher <hs@denx.de>
2009-08-28Use common code for Matrix Vision boardsAndré Schwarz
Clean up existing boards (mvBC-P/MPC5200 and mvBL-M7/MPC8343) by using common code. Signed-off-by: André Schwarz <andre.schwarz@matrix-vision.de>
2009-07-27mpc83xx: CONFIG_83XX_GENERIC_PCI is now synonymous with CONFIG_PCI; remove ↵Kim Phillips
the former Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-1283xx: Replace CONFIG_MPC83[0-9]X with MPC83[0-9]xPeter Tyser
Use the standard lowercase "x" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-1283xx: Replace CONFIG_MPC83XX with CONFIG_MPC83xxPeter Tyser
Use the standard lowercase "xx" capitalization that other Freescale architectures use for CPU defines to prevent confusion and errors Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-04-01mpc83xx: Set guarded bit on BAT that covers the end of the address spaceScott Wood
The mpc8313erdb board currently sets DBAT6 to cover all of the final 256MiB of address space; however, not all of this space is covered by a device. In particular, flash sits at 0xfe000000-0xfe7fffff, and nothing is mapped at the far end of the address space. In zlib, there is a loop that references p[-1] if p is non-NULL. Under some circumstances, this leads to the CPU speculatively loading from 0xfffffff8 if p is NULL. This leads to a machine check. Signed-off-by: Scott Wood <scottwood@freescale.com> continuation to the remaining mpc83xx boards that suffer from the same problem. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-08-25change mvBL-M7 default env and move to vendor subdirAndre Schwarz
fix mvBL-M7 config and move to matrix_vision subdir Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-07-07update mvBL-M7 board configAndre Schwarz
update mvBL-M7 config file to use UBOOT_VERSION and define CONFIG_HIGH_BATS. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-10mpc83xx: MVBLM7: minor build fixupsKim Phillips
2008-06-10add MPC8343 based board mvBlueLYNX-M7 (doc+config)Andre Schwarz
Add MPC8343 based board mvBlueLYNX-M7. It's a single board stereo camera system. Please read doc/README.mvblm7 for details. Signed-off-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
