path: root/include/configs/MPC8641HPCN.h
2008-01-2486xx: Add reginfo commandBecky Bruce
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-2486xx: Support new law setup method and convert mpc8641Becky Bruce
Adds the support code in cpu/mpc86xx for the new law setup code recently created fsl_law.c, and changes the MPC8641HPCN config to use this code. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-01-1786xx: enable command-line editingTimur Tabi
Enable command-line editing for all MPC86xx boards. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-01-16FSL: Convert board/freescale/common/Makefile to use CONFIG_Jon Loeliger
Convert the board/freescale/common/Makefile to use CONFIG_* options to select which files to conditionally compile into the board/freescale/common library rather than conditionally compiling entire files. Now handles:: CONFIG_FSL_PIXIS CONFIG_FSL_DIU_FB CONFIG_PQ_MDS_PIB CONFIG_ID_EEPROM is introduced until CFG_ID_EEPROM is gone. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-03Don't slam #undef DEBUG in the 8641HPCN config file.Jon Loeliger
Doing so prevents it from being individually set and useful in other files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-03Convert MPC8641HPCN to use libfdt.Jon Loeliger
Assumes the presence of the aliases node in the DTS to locate the ethernet, pci and serial nodes for fixups. Use consistent fdtaddr and fdtfile in environment variables. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-11-07Unify pixis_reset altbank across board familiesJason Jin
Basically, refactor the CFG_PIXIS_VBOOT_MASK values into the separate board config files. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-11-03Fix USB support issue for MPC8641HPCN board.Zhang Wei
The configuration file has already enabled USB, but it missed definition of CFG_OHCI_SWAP_REG_ACCESS, the USB on MPC8641HPCN can not work because of the wrong USB register endian. And add the USB command to U-Boot commands list. Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
2007-08-29support board vendor-common makefilesKim Phillips
if a board/$(VENDOR)/common/Makefile exists, build it. also add the first such case, board/freescale/common/Makefile, to handle building board-shared EEPROM, PIXIS, and MDS-PIB code, as dictated by board configuration. thusly get rid of alternate build dir errors such as: FATAL: can't create /work/wd/tmp/u-boot-ppc/board/freescale/mpc8360emds/../common/pq-mds-pib.o: No such file or directory by putting the common/ mkdir command in its proper place (the common Makefile). Common bits from existing individual board Makefiles have been removed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-08-06Configurations for ATI video card BIOS emulatorJason Jin
This patch add definition of the BIOS emulator and the ATI framebuffer driver for MPC8641HPCN board. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
2007-08-06Make MPC8641's PCI/PCI-E driver a common driver for many FSL parts.Ed Swarthout
All of the PCI/PCI-Express driver and initialization code that was in the MPC8641HPCN port has now been moved into the common drivers/fsl_pci_init.c. In a subsequent patch, this will be utilized by the 85xx ports as well. Common PCI-E IMMAP register blocks for FSL 85xx/86xx are added. Also enable the second PCI-Express controller on 8641 by getting its BATS and CFG_ setup right. Fixed a u16 vendor compiler warning in AHCI driver too. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-07-10include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-04configs/ mpc86xx: Rewrite command line options using new CONFIG_CMD-* style.Jon Loeliger
2007-07-03Merge with /home/wd/git/u-boot/custodian/u-boot-testingWolfgang Denk
2007-06-06Add USB PCI-OHCI, USB keyboard and event poll support to theZhang Wei
MPC8641HPCN board config file. Signed-off-by: Zhang Wei <wei.zhang@freescale.com>
2007-06-05mpc8641 image size cleanupEd Swarthout
e600 does not have a bootpg restriction. Move the version string to beginning of image at fff00000. Resetvec.S is not needed. Update flash copy instructions. Add tftpflash env variable Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-03-22Add flash cmd function to 8641HPCN rambootJason Jin
Also fixes some commmand for 8641 HPCN ramboot case. Signed-off-by: Jason Jin <jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-19Moved i2c driver out of cpu/mpc86xx/i2c.c into drivers/fsl_i2c.cJon Loeliger
in an effort to begin to unify the umpteen FSL I2C drivers that are all otherwise very similar. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-10-10Fix whitespace issues.Jon Loeliger
2006-08-25Change ramdiskaddr and dtbaddrHaiying Wang
Remove PEX fluff commands. Signed-off-by: Haiying Wang <haiying.wang@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-08-23Add AHCI define and sata support for MPC8641HPCN board.Jin Zhengxiong
Signed-off-by:Jason Jin<jason.jin@freescale.com>
2006-08-23Add dtb boot-up parameter to default boot commands.Zhang Wei
2006-08-14Fix BAT0 to actually be cacheable, non-guarded as documented.Jon Loeliger
2006-07-28Fix 8641HPCN timebaseJohn Traill
2006-07-13Add support for reading and writing mac addresses to or from ID EEPROM.Haiying Wang
Added code for reading and writing Mac addresses to/from ID EEPROM(0x57). With attached patch, we can use command "mac/mac read/mac save/" to read and write EEPROM under u-boot prompt. U-boot will calculate the checksum of EEPROM while bootup, if it is right, then u-boot will check whether the mac address of eTSEC0/1/2/3 is availalbe (non-zero). If there is mac address availabe in EEPROM, u-boot will use it, otherewise, u-boot will use the mac address defined in MPC8641HPCN.h. This matches the requirement to set unique mac address for each TSEC port. Signed-off-by: Haiying Wang <haiying.wang@freescale.com> Signed-off-by: York Sun <yorksun@freescale.com>
2006-07-13Fixed initrd issue by define big RAMJin Zhengxiong
Signed-off-by:Jason Jin <Jason.jin@freescale.com>
2006-06-27Fix RTL8139 in big endianJin Zhengxiong-R64188
signed-off-by: Jason Jin <Jason.Jin@freescale.com> signed-off-by: Wei Zhang <wei.zhang@freescale.com>
2006-06-27Enable PCIE1 for MPC8641HPCN boardJin Zhengxiong-R64188
2006-05-19Enable dual DDR controllers and interleaving.Jon Loeliger
2006-05-19Update 86xx address map and LAWBARs.Jon Loeliger
2006-05-09Get MPC8641HPCN flash images working.Jon Loeliger
Enable the CFI driver. Remove bogus LAWBAR7 cruft. Use correct TEXT_BASE, Fixup load script. Enable SPD EEPROM during DDR setup. Use generic RFC 1918 IP addresses by default.
2006-04-27Cleanup whitespaces and style issues.Jon Loeliger
Removed //-style comments. Use 80-column lines. Remove trailing whitespace. Remove dead code and debug cruft.
2006-04-26Initial support for MPC8641 HPCN board.Jon Loeliger
