path: root/include/configs/MPC8610HPCD.h
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10cmd_mac: Move conditional compilation to MakefileJean-Christophe PLAGNIOL-VILLARD
finish remaning CFG_ID_EEPROM in CONFIG_ID_EEPROM start in commit ad8f8687b78c3e917b173f038926695383c55555 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-08-27FSL DDR: Convert MPC8610HPCD to new DDR code.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-15Update Freescale sys_eeprom.c to handle CCID formatsTimur Tabi
Update the sys_eeprom.c file to handle both NXID and CCID EEPROM formats. The NXID format replaces the older CCID format, but it's important to support both since most boards out there still use the CCID format. This change is in preparation for using one file to handle both formats. This will also unify EEPROM support for all Freescale 85xx and 86xx boards. Also update the 86xx board header files to use the standard CFG_I2C_EEPROM_ADDR instead of ID_EEPROM_ADDR. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-07-07Feed the watchdog in u-boot for 8610 board.Jason Jin
The watchdog on 8610 board is enabled by setting sw[6] to on. Once enabled, the watchdog can not be disabled by software. So feed the dog in u-boot is necessary for normal operation. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2008-06-06Merge commit 'wd/master'Jon Loeliger
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-05-19mpc86xx: Removed unused and unconfigured memory test code.Jon Loeliger
Besides, other common code exists. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-04-2985xx/86xx: Rename ext_refrec to timing_cfg_3 to match docsKumar Gala
All the 85xx and 86xx UM describe the register as timing_cfg_3 not as ext_refrec. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-02-208610HPCD: Don't use VIDEO/CFB_CONSOLE by default.Jon Loeliger
Without an actual supported video card hooked up, enabling the CONFIG_VIDEO by default just makes it look broken by routing all console output to the video card. Don't. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-2486xx: Add reginfo commandBecky Bruce
2008-01-2486xx: Convert mpc8610hpcd to new law setup method.Becky Bruce
2008-01-1786xx: enable command-line editingTimur Tabi
Enable command-line editing for all MPC86xx boards. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-01-16FSL: Convert board/freescale/common/Makefile to use CONFIG_Jon Loeliger
Convert the board/freescale/common/Makefile to use CONFIG_* options to select which files to conditionally compile into the board/freescale/common library rather than conditionally compiling entire files. Now handles:: CONFIG_FSL_PIXIS CONFIG_FSL_DIU_FB CONFIG_PQ_MDS_PIB CONFIG_ID_EEPROM is introduced until CFG_ID_EEPROM is gone. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-16Use CONFIG_ULI526X as MPC8610HPCD default Ethernet driverRoy Zang
Use driver/net/uli526x.c as MPC8610HPCD default Ethernet driver. Remove unused ethernet CONFIG_ options. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-01-0986xx: Remove cache config from configs.hJon Loeliger
Just use the standard defines in asm/cache.h. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-01-09Convert MPC8610HPCD to use libfdt.Jon Loeliger
Assumes the presence of the aliases node in the DTS to locate the pci and serial nodes for fixups. Use consistent fdtaddr and fdtfile in environment variables. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-11-208610HPCD: Enable the 8610 Display Interface UnitJon Loeliger
2007-11-13Enable ULi1575 Ethernet support in 8610HPCD configRoy Zang
2007-11-078610: Add console frame buffer support to FSL 8610 DIU driver.York Sun
Add cfb console support to FSL 8610 DIU driver. Inspect board version from PIXIS to obtain correct pixel format. Use #define CONFIG_VIDEO in config file to enable fb console. To switch monitor, set monitor variable to 0 - DVI, 1 - Single link LVDS, 2 - Double link LVDS followed by "diufb init". Preserve logo bitmap at the top of the fb console. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-11-078610: Add 8610 DIU display driverYork Sun
1280x1024 and 1024x768 @ 32 bpp are supported now. DVI, Single-link LVDS, Double-link LVDS are all supported. Environmental variable "monitor" is used to specify monitor port. A new command "diufb" is introduced to reinitialize monitor and display a BMP file in the memory. So far, 1-bit, 4-bit, 8-bit and 24-bit BMP formats are supported. diufb init - initialize the diu driver Enable the port specified in the environmental variable "monitor" diufb addr - display bmp file in memory. The bmp image should be no bigger than the resolution, 1280x1024 for DVI and double-link LVDS, 1024x768 for single-link LVDS. Note, this driver allocate memory but doesn't free it after use It is written on purpose -- to avoid a failure of reallocation due to memory fragement. ECC of DDR is disabled for DIU performance. L2 data cache is also disabled. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Jon loeliger <jdl@freescale.com>
2007-11-078610: Make some extra debug environment variables conditional.York Sun
One may #define ENV_DEBUG to get them back again. Signed-off-by: York Sun <yorksun@freescale.com>
2007-11-078610: Actually enable pixis_reset CONFIGsJason Jin
2007-11-07Fix the BAT definition of PCI IO on 8610 boardJason Jin
The address in the BAT register is aligned with the BAT size. The original definition actually did not define BAT for PCIE2 IO. This patch fix this. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2007-10-17Initial mpc8610hpcd cpu/, README and include/ files.Jon Loeliger
Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Signed-off-by: Mahesh Jade <mahesh.jade@freescale.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Jon Loeliger <jdl@freescale.com>
