path: root/include/configs/MPC8569MDS.h
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-01powerpc: convert selected boards to generic board structureYork Sun
Convert MPC8540ADS, MPC8541CDS, MPC8544CDS, MPC8548CDS, MPC8555CDS, MPC8560ADS, MPC8568MDS, MPC8569MDS, MPC8610HPCD to use generic board structure. Signed-off-by: York Sun <yorksun@freescale.com>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2014-06-05nand_spl: remove MPC8569MDS_NAND supportMasahiro Yamada
Commit 3d5a335c announced that all the nand_spl boards would be removed before v2014.07 release. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-04-22QE/FMAN: modify CONFIG_SYS_QE_FMAN_FW_ADDR to CONFIG_SYS_FMAN_FW_ADDR and ↵Zhao Qiang
CONFIG_SYS_QE_FW_ADDR CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address. Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address, and CONFIG_SYS_QE_FW_ADDR for QE microcode address. Signed-off-by: Zhao Qiang <B45475@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2014-02-25kbuild: Move linker sciript check to prepare1Masahiro Yamada
Same as the previous commit. Move sanity check to prepare1 target to avoid nasty troubles. Before this commit, LDSCRIPT existence was not checked when it was specified by CONFIG_SYS_LDSCRIPT. Now LDSCRIPT existence is checked for all boards. $(wildcard $(LDSCRIPT)) must point to the linker scripts with absolute path. Otherwise, make will terminate with a false error on out-of-tree build. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-11-29powerpc/85xx: clean up and document the QE/FMAN microcode macrosTimur Tabi
Several macros are used to identify and locate the microcode binary image that U-boot needs to upload to the QE or Fman. Both the QE and the Fman use the QE Firmware binary format to package their respective microcode data, which is why the same macros are used for both. A given SOC will only have a QE or an Fman, so this is safe. Unfortunately, the current macro definition and usage has inconsistencies. For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address of NAND. There's no way to know by looking at a variable how it's supposed to be used. In the future, the code which uploads QE firmware and Fman firmware will be merged. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-09powerpc/85xx: Fix NAND SPL supportKumar Gala
We cause CCSRBAR to be relocated in the SPL phase of NAND boot which isn't expected and breaks things. Fixing the board config.h to NOT relocate CCSR during the CONFIG_NAND_SPL phase. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-20fsl: Change fsl_phy_enet_if to phy_interface_tAndy Fleming
The fsl_phy_enet_if enum was, essentially, the phy_interface_t enum. This meant that drivers which used fsl_phy_enet_if to deal with PHY interfaces would have to convert between the two (or we would have to have them mirror each other, and deal with the ensuing maintenance headache). Instead, we switch all clients of fsl_phy_enet_if over to phy_interface_t, which should become the standard, anyway. Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-08powerpc/85xx: rename NAND prefixes to CONFIG_SYSMatthew McClintock
renaming 85xx define CONFIG_NAND_OR_PRELIM to CONFIG_SYS_NAND_OR_PRELIM and CONFIG_NAND_BR_PRELIM to CONFIG_SYS_NAND_BR_PRELIM to use the more appropriate CONFIG_SYS prefix as well as be consistent with 83xx. Signed-off-by: Matthew McClintock <msm@freescale.com> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Remove config.mk for nand linker scriptKumar Gala
Move the include of mpc85xx/u-boot-nand.lds to utilize CONFIG_SYS_LDSCRIPT rather than having an explicit config.mk Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Convert MPC8569MDS to use common SRIO init codeKumar Gala
2011-01-14powerpc/85xx: Rework MPC8569MDS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8569MDS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14fsl_esdhc: Fix esdhc disabled problem on some platformsChenhui Zhao
Some new platform's esdhc pins don't share with other function. The eSDHC shouldn't be disabled, even if "esdhc" isn't defined in hwconfig env variable. Use CONFIG_FSL_ESDHC_PIN_MUX to fix this problem. Signed-off-by: Chenhui Zhao <b26998@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14MPC8568/MPC8569: Remove CONFIG_DDR_DLL defineBecky Bruce
Neither of these parts should have the erratum this is meant to work around. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
