path: root/include/configs/MPC8569MDS.h
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-10-07mpc8569mds: fix consuming long time while relocating code.Haiying Wang
The original code maps boot flash as non-cacheable region. When calling relocate_code in flash to copy u-boot from flash to ddr, every loop copy command is read from flash. The flash read speed will be the bottleneck, which consuming long time to do this operation. To resovle this, map the boot flash as write-through cache via tlb. And set tlb to remap the flash after code executing in ddr, to confirm flash erase operation properly done. Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-07mpc8569mds: fix CONFIG_ENV_SIZEHaiying Wang
CONFIG_ENV_SIZE of MPC8569MDS was wrongly set to CONFIG_ENV_SECT_SIZE which is 128KB, so it took longer time to do crc32 calculation for ENV than it should do. It causes the bootup for MPC8569MDS significantly slow. This patch fixs it to 0x2000(8KB), also fix the comment for CONFIG_ENV_SECT_SIZE to correct size. Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-09net: rename "FSL UECx" net interfaces "UECx"Kim Phillips
continuation of commit 2ecc2262d66a286e3aac79005bcb5f461312dea8 "net ppc: fix ethernet device names with spaces" (currently in u-boot-net.git) for QE based parts. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07ppc/85xx: Use CONFIG_NS16550_MIN_FUNCTIONS to reduce NAND_SPL sizeKumar Gala
The MPC8536DS_NAND SPL build was failing due to code size increase introduced by commit: commit 33f57bd553edf29dffef5a6c7d76e169c79a6049 Author: Kumar Gala <galak@kernel.crashing.org> Date: Fri Mar 26 15:14:43 2010 -0500 85xx: Fix enabling of L1 cache parity on secondary cores We built in some NS16550 functions that we dont need and can get rid of them via CONFIG_NS16550_MIN_FUNCTIONS. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-02-03Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2010-01-3183xx, uec: split enet_interface in two variablesHeiko Schocher
There's no sensible reason to unite speed and interface type into one variable. So split this variable enet_interface into two vars: enet_interface_type, which hold the interface type and speed. Also: add the possibility for switching between 10 and 100 MBit interfaces on the fly, when running in FAST_ETH mode. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-27Nand boot: Add nand boot support for MPC8569mds boardLiu Yu
This patch add nand boot support for MPC8569mds board. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2010-01-25ppc/85xx: Add ATM config for MPC8569MDSLiu Yu
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05mpc85xx: Add 4-bits eSDHC support for MPC8569E-MDS boardsAnton Vorontsov
Thanks to "Errata to MPC8569E PowerQUICC III Integrated Host Processor Family Reference Manual, Rev. 0" document, which describes all eSDHC pins, we can add 4-bits eSDHC support for MPC8569E-MDS boards. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-10-27mpc85xx: Add eLBC NAND support for MPC8569E-MDS boardsAnton Vorontsov
Simply add some defines, and adjust TLBe setup to include some space for eLBC NAND. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-10-27mpc85xx: Add eSDHC support for MPC8569E-MDS boardsAnton Vorontsov
eSDHC is mutually exlusive with UART0 (in 4-bits mode) and I2C2 (in 1-bit mode). When eSDHC is used, we should switch u-boot console to UART1, and make the proper device-tree fixups. Because of an erratum in prototype boards it is impossible to use eSDHC without disabling UART0 (which makes it quite easy to 'brick' the board by simply issung 'setenv hwconfig esdhc', and not able to interact with U-Boot anylonger). So, but default we assume that the board is a prototype, which is a most safe assumption. There is no way to determine board revision from a register, so we use hwconfig. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-29Update Freescale copyrights to remove "All Rights Reserved"Kumar Gala
"All Rights Reserved" conflicts with the GPL. Signed-off-by: Kumar Gala <kumar.gala@freescale.com>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add UEC6 and UEC8 at SGMII mode for MPC8569MDSHaiying Wang
On MPC8569MDS board, UCC6 and UCC8 can be configured to work at SGMII mode via UEM on PB board. Since MPC8569 supports up to 4 Gigabit Ethernet ports, we disable UEC6 and UEC8 by default. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add RMII support for MPC8569MDSHaiying Wang
This patch supports UCC working at RMII mode on PIB board, fixup fdt blob to support rmii in kernel. It also changes the name of enable_mpc8569mds_qe_mdio to enalbe_mpc8569mds_qe_uec which is more accurate. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Add UEC3 and UEC4 support for MPC8569MDSHaiying Wang
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-1285xx: Add PIB support at CS4/CS5 for MPC8569MDSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Yu Liu <Yu.Liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-1285xx: Fix some settings for MPC8569MDS boardHaiying Wang
- Increase the size of malloc to 512KB because MPC8569MDS needs more memory for malloc to support up to eight Ethernet interfaces. - Move Environment address out of uboot thus the saved environment variables will not be erased after u-boot is re-programmed. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-0985xx: Fix the wrong SYS_CLK_IN for 8569MDSDave Liu
The SYS_CLK_IN of MPC8569MDS is 66.66MHz, The DDR_CLK_IN is same with SYS_CLK_IN in 8569 processor. so, change the SYS_CLK_IN from 66MHz to 66.66MHz. Signed-off-by: Dave Liu <daveliu@freescale.com>
2009-03-30MPC85xx: Add MPC8569MDS board supportHaiying Wang
This patch adds MPC8569MDS board support. The UART, QE UEC1 and UEC2, BRD EEPROM on I2C2 bus, PCI express and DDR3 SPD are supported in this patch. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Hillel Avni <Hillel.Avni@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
