path: root/include/configs/MPC8569MDS.h
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2011-11-29powerpc/85xx: clean up and document the QE/FMAN microcode macrosTimur Tabi
Several macros are used to identify and locate the microcode binary image that U-boot needs to upload to the QE or Fman. Both the QE and the Fman use the QE Firmware binary format to package their respective microcode data, which is why the same macros are used for both. A given SOC will only have a QE or an Fman, so this is safe. Unfortunately, the current macro definition and usage has inconsistencies. For example, CONFIG_SYS_FMAN_FW_ADDR was used to define the address of Fman firmware in NOR flash, but CONFIG_SYS_QE_FW_IN_NAND contains the address of NAND. There's no way to know by looking at a variable how it's supposed to be used. In the future, the code which uploads QE firmware and Fman firmware will be merged. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-11-09powerpc/85xx: Fix NAND SPL supportKumar Gala
We cause CCSRBAR to be relocated in the SPL phase of NAND boot which isn't expected and breaks things. Fixing the board config.h to NOT relocate CCSR during the CONFIG_NAND_SPL phase. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-20fsl: Change fsl_phy_enet_if to phy_interface_tAndy Fleming
The fsl_phy_enet_if enum was, essentially, the phy_interface_t enum. This meant that drivers which used fsl_phy_enet_if to deal with PHY interfaces would have to convert between the two (or we would have to have them mirror each other, and deal with the ensuing maintenance headache). Instead, we switch all clients of fsl_phy_enet_if over to phy_interface_t, which should become the standard, anyway. Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Detlev Zundel <dzu@denx.de>
2011-04-08powerpc/85xx: rename NAND prefixes to CONFIG_SYSMatthew McClintock
renaming 85xx define CONFIG_NAND_OR_PRELIM to CONFIG_SYS_NAND_OR_PRELIM and CONFIG_NAND_BR_PRELIM to CONFIG_SYS_NAND_BR_PRELIM to use the more appropriate CONFIG_SYS prefix as well as be consistent with 83xx. Signed-off-by: Matthew McClintock <msm@freescale.com> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/8xxx: Refactor fsl_ddr_get_spd into common code from boardKumar Gala
Move fsl_ddr_get_spd into common mpc8xxx/ddr/main.c as most boards pretty much do the same thing. The only variations are in how many controllers or DIMMs per controller exist. To make this work we standardize on the names of the SPD_EEPROM_ADDRESS defines based on the use case of the board. We allow boards to override get_spd to either do board specific fixups to the SPD data or deal with any unique behavior of how the SPD eeproms are wired up. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Remove config.mk for nand linker scriptKumar Gala
Move the include of mpc85xx/u-boot-nand.lds to utilize CONFIG_SYS_LDSCRIPT rather than having an explicit config.mk Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Convert MPC8569MDS to use common SRIO init codeKumar Gala
2011-01-14powerpc/85xx: Rework MPC8569MDS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8569MDS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14fsl_esdhc: Fix esdhc disabled problem on some platformsChenhui Zhao
Some new platform's esdhc pins don't share with other function. The eSDHC shouldn't be disabled, even if "esdhc" isn't defined in hwconfig env variable. Use CONFIG_FSL_ESDHC_PIN_MUX to fix this problem. Signed-off-by: Chenhui Zhao <b26998@freescale.com> Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14MPC8568/MPC8569: Remove CONFIG_DDR_DLL defineBecky Bruce
Neither of these parts should have the erratum this is meant to work around. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14mpc8569mds: Remove unnecessary CONFIG_SYS_LBC_SDRAM_BASE definitionBecky Bruce
This isn't used - delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-30powerpc/85xx: Introduce CONFIG_SYS_EXTRA_ENV_RELOCKumar Gala
Some systems need to relocate the env_addr pointer early because the location it points to will get invalidated before env_relocate is called. One example is on systems that might use a L2 or L3 cache in SRAM mode and initialize that cache from SRAM mode back to being a cache in cpu_init_r. We set this on the 85xx boards that have support for NAND, SPI, or SDHC/MMC boot support as they use a secondary cache in SRAM mode and need the env_addr pointer relocated since we change from SRAM to normal cache mode in cpu_init_r. Also removed CONFIG_SYS_SPL as its not used anywhere. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12powerpc/85xx: add CONFIG_SYS_TEXT_BASE_SPL for 85xx nand spl buildHaiying Wang
Introduce a SPL specific CONFIG_SYS_TEXT_BASE_SPL define to be used by the linker. This has similiar semantics to CONFIG_SYS_TEXT_BASE however since SPL is a unqiue image we introduce a new variable to control its text base address. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-10powerpc/8xxx: Enable e1000 driver on some FSL boardsKumar Gala
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-10-07mpc8569mds: fix consuming long time while relocating code.Haiying Wang
The original code maps boot flash as non-cacheable region. When calling relocate_code in flash to copy u-boot from flash to ddr, every loop copy command is read from flash. The flash read speed will be the bottleneck, which consuming long time to do this operation. To resovle this, map the boot flash as write-through cache via tlb. And set tlb to remap the flash after code executing in ddr, to confirm flash erase operation properly done. Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-07mpc8569mds: fix CONFIG_ENV_SIZEHaiying Wang
CONFIG_ENV_SIZE of MPC8569MDS was wrongly set to CONFIG_ENV_SECT_SIZE which is 128KB, so it took longer time to do crc32 calculation for ENV than it should do. It causes the bootup for MPC8569MDS significantly slow. This patch fixs it to 0x2000(8KB), also fix the comment for CONFIG_ENV_SECT_SIZE to correct size. Signed-off-by: Kai.Jiang <Kai.Jiang@freescale.com Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-09net: rename "FSL UECx" net interfaces "UECx"Kim Phillips
continuation of commit 2ecc2262d66a286e3aac79005bcb5f461312dea8 "net ppc: fix ethernet device names with spaces" (currently in u-boot-net.git) for QE based parts. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07ppc/85xx: Use CONFIG_NS16550_MIN_FUNCTIONS to reduce NAND_SPL sizeKumar Gala
The MPC8536DS_NAND SPL build was failing due to code size increase introduced by commit: commit 33f57bd553edf29dffef5a6c7d76e169c79a6049 Author: Kumar Gala <galak@kernel.crashing.org> Date: Fri Mar 26 15:14:43 2010 -0500 85xx: Fix enabling of L1 cache parity on secondary cores We built in some NS16550 functions that we dont need and can get rid of them via CONFIG_NS16550_MIN_FUNCTIONS. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-02-03Merge branch 'master' of git://git.denx.de/u-boot-netWolfgang Denk
2010-01-3183xx, uec: split enet_interface in two variablesHeiko Schocher
There's no sensible reason to unite speed and interface type into one variable. So split this variable enet_interface into two vars: enet_interface_type, which hold the interface type and speed. Also: add the possibility for switching between 10 and 100 MBit interfaces on the fly, when running in FAST_ETH mode. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-01-27Nand boot: Add nand boot support for MPC8569mds boardLiu Yu
This patch add nand boot support for MPC8569mds board. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2010-01-25ppc/85xx: Add ATM config for MPC8569MDSLiu Yu
Signed-off-by: Liu Yu <yu.liu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-01-05mpc85xx: Add 4-bits eSDHC support for MPC8569E-MDS boardsAnton Vorontsov
Thanks to "Errata to MPC8569E PowerQUICC III Integrated Host Processor Family Reference Manual, Rev. 0" document, which describes all eSDHC pins, we can add 4-bits eSDHC support for MPC8569E-MDS boards. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
