CONFIG_ENV_IS_IN_FLASH
CONFIG_CMD_IRQ
Move this in to Kconfig with a default of 115200.
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
[trini: Run moveconfig.py, reword commit slightly]
configs/ls1046aqds_defconfig
configs/ls1046aqds_nand_defconfig
configs/ls1046aqds_qspi_defconfig
configs/ls1046aqds_sdcard_ifc_defconfig
configs/ls1046aqds_sdcard_qspi_defconfig
configs/ls1046ardb_emmc_defconfig
configs/ls1046ardb_qspi_defconfig
configs/ls1046ardb_sdcard_defconfig
Enable ELBC from Kconfig.
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Reviewed-by: York Sun <york.sun@nxp.com>
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC.
Let's create an entry for "config GENERIC_MMC" with "default MMC",
then convert all macro defines in headers to Kconfig. Almost all
of the defines will go away.
I see only two exceptions:
configs/blanche_defconfig
configs/sandbox_noblk_defconfig
They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something
might be wrong with these two boards, so should be checked later.
Anyway, this is the output of the moveconfig tool.
This commit was created as follows:
[1] create a config entry in drivers/mmc/Kconfig
[2] tools/moveconfig.py -r HEAD GENERIC_MMC
[3] manual clean-up of garbage comments in doc/README.* and
include/configs/*.h
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_BOARD_EARLY_INIT_F
Use option NUM_DDR_CONTROLLERS in ddr Kconfig and clean up existing
usage in ls102xa and fsl-layerscape. Remove all powerpc macros in
config header and board header files.
Signed-off-by: York Sun <york.sun@nxp.com>
Create driver/ddr/fsl/Kconfig and move existing options. Clean up
existing macros.
[trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s]
Use Kconfig option for E500 and E500MC macros.
Commit 7a777f6d6f35 ("mmc: Add generic Kconfig option") created
a Kconfig entry for this option without any actual moves, then
commit 44c798799f66 ("sunxi: Use Kconfig CONFIG_MMC") moved
instances only for SUNXI.
We generally do not like such partial moves. This kind of work
is automated by tools/moveconfig.py, so it is pretty easy to
complete this move.
I am adding "default ARM || PPC || SANDBOX" (suggested by Tom).
This shortens the configs and will ease new board porting.
[1] Edit Kconfig (remove the "depends on", add the "default",
copy the prompt and help message from Linux)
[2] Run 'tools/moveconfig.py -y -s -r HEAD MMC'
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Some header files have this macro defined conditionally and
redefined unconditionally. Remove all existing definitions.
Use CONFIG_TARGET_MPC8569MDS instead.
Replace CONFIG_MPC8569 with ARCH_MPC8569 in Kconfig and clean up existing
macros.
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig
to use that.
[trini: Re-generate configs and include/configs/ changes]
Add 'PCI' as a menu option and migrate all existing users.
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
A number of moveconfig.py runs have left a instances of multiple empty
lines in a row. Correct this to a single empty line.
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
For most PPC platforms, they will call the first get_clocks() in
init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is
then defined to call the second get_clocks(), which should be
redundant for PPC.
Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
Reviewed-by: York Sun <yorksun@freescale.com>
get_clocks() should not be limited by ESDHC.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards.
Convert MPC8540ADS, MPC8541CDS, MPC8544CDS, MPC8548CDS, MPC8555CDS,
MPC8560ADS, MPC8568MDS, MPC8569MDS, MPC8610HPCD to use generic board
structure.
Signed-off-by: York Sun <yorksun@freescale.com>
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
them from include/configs.
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some
time and a more generic method of NAND verification now exists in U-Boot.
Tested-by: Heiko Schocher <hs@denx.de>
Acked-by: Heiko Schocher <hs@denx.de>
Commit 3d5a335c announced that all the nand_spl boards
would be removed before v2014.07 release.
CONFIG_SYS_QE_FW_ADDR
CONFIG_SYS_QE_FMAN_FW_ADDR is used to both Fman and QE for microcode address.
Now using CONFIG_SYS_FMAN_FW_ADDR for Fman microcode address,
and CONFIG_SYS_QE_FW_ADDR for QE microcode address.
Signed-off-by: Zhao Qiang <B45475@freescale.com>
Same as the previous commit.
Move sanity check to prepare1 target to avoid nasty troubles.
Before this commit, LDSCRIPT existence was not checked
when it was specified by CONFIG_SYS_LDSCRIPT.
Now LDSCRIPT existence is checked for all boards.
$(wildcard $(LDSCRIPT)) must point to the linker scripts
with absolute path.
Otherwise, make will terminate with a false error
on out-of-tree build.
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk
because all target boards with mpc85xx cpu define it.
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years
ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should
care about this parameter or it should be gone completely.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs.
The similar DDR controllers will be used for ARM-based SoCs.
Remove platform CONFIG_SYS_HZ definition for configs A-Z*.
The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
- added to soft_i2c driver new multibus/multiadpater support
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
Remove any notion of CONFIG_SERIAL_MULTI from board config files.
Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless
to specify this config option in the board config files. Therefore
remove it.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Stefan Roese <sr@denx.de>
