path: root/include/configs/MPC8568MDS.h
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Convert MPC8568 MDS to new TLB setupKumar Gala
2008-01-1685xx: convert remaining 85xx boards over to use new LAW init codeKumar Gala
Converted ATUM8548, MPC8568 MDS, MPC8540 EVAL, and TQM85xx boards over to use new LAW init code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Handle MPC85xx PCIe reset errata (PCI-Ex 38)Kumar Gala
On the MPC85xx boards that have PCIe enable the PCIe errata fix. (MPC8544DS, MPC8548CDS, MPC8568MDS). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Update Freescale MPC85xx ADS/CDS/MDS board configKumar Gala
* Enabled CONFIG_CMD_ELF Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
* Removed some misc environment setup * Enabled CONFIG_CMDLINE_EDITING Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Update MPC8568 MDS to use libfdtKumar Gala
Updated the MPC8568 MDS config to use libfdt and assume use of aliases for ethernet, pci, and serial for the various fixups that are done. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Add PCI Express support on MPC8568MDSHaiying Wang
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-11-19Move CONFIG_QE out of CONFIG_PCI wrap for MPC8568MDSHaiying Wang
CONFIG_QE shouldn't be in the wrap of CONFIG_PCI, fix it. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-10-19Set OF_STDOUT_PATH to match the default console on MPC8568 MDSKumar Gala
On the MPC8568 MDS we use ttyS0, UART0, etc. as the standard configured console. Make it so we match that config what we tell Linux as the early STDOUT console. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-29Enable L2 cache for MPC8568MDS boardHaiying Wang
The L2 cache size is 512KB for 8568, print out the correct informaiton. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Fix numerous bugs in the 8568 UEC supportAndy Fleming
Actually, fixed a large bug in the UEC for *all* platforms. How did this ever work? uec_init() did not follow the spec for eth_init(), and returned 0 on success. Switch it to return the link like tsec_init() (and 0 on error) The immap for the 8568 was defined based on MPC8568, rather than CONFIG_MPC8568 CONFIG_QE was off CONFIG_ETHPRIME was set to "Freescale GETH". Now is "FSL UEC0" Fixed a comment about the ranges for CONFIG_ETHPRIME if TSEC_ENET is enabled Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add support for UEC to 8568Andy Fleming
Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-14Add PCI support for MPC8568MDS boardHaiying Wang
This patch is against u-boot-mpc85xx.git of www.denx.com Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Ebony Zhu <ebony.zhu@freescale.com>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-05-05Coding stylke cleanup; update CHANGELOG.Wolfgang Denk
2007-05-02Add support for the 8568 MDS boardAndy Fleming
This included some changes to common files: * Add 8568 processor SVR to various places * Add support for setting the qe bus-frequency value in the dts * Add the 8568MDS target to the Makefile Signed-off-by: Andy Fleming <afleming@freescale.com>
