path: root/include/configs/MPC8560ADS.h
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-10Update all board to support new bbmiiphy driver (with multibus support)Luigi 'Comio' Mantellini
Signed-off-by: Luigi 'Comio' Mantellini <luigi.mantellini@idf-hit.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-09-22ppc: Clean up calling of phy_reset() during initPeter Tyser
Remove board-specific #ifdefs for calling phy_reset() during initializtion Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-3085xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
2009-02-18rename CONFIG_CMD_ENV to CONFIG_CMD_SAVEENVMike Frysinger
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command rather than a generic "env" command, or anything else related to the environment. So, let's make sure the define is named accordingly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_IO_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI IO space is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_MEM_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI memory is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Convert CONFIG_SYS_PCI*_IO_BASE to _IO_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead of _IO_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Convert CONFIG_SYS_{PCI*,RIO*}_MEM_BASE to _MEM_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead of _MEM_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-10-2485xx: Enable 64-bit PCI resources on all Freescale boardsKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-1885xx: Enable interrupt and setexpr commands on Freescale 85xx boardsKumar Gala
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-08-27FSL DDR: Convert MPC8560ADS to new DDR code.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-14Fix indentation for default boot environment variablesAndy Fleming
This was proposed by Paul Gortmaker in response to Wolfgang's comments on similar #defines in sbc8560.h. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-11FSL LAW: Keep track of LAW allocationsKumar Gala
Make it so we keep track of which LAWs have allocated and provide a function (set_next_law) which can allocate a LAW for us if one is free. In the future we will move to doing more "dynamic" LAW allocation since the majority of users dont really care about what LAW number they are at. Also, add CONFIG_MPC8540 or CONFIG_MPC8560 to those boards which needed them Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-1185xx: remove dummy board_early_init_fKumar Gala
A number of board ports have empty version of board_early_init_f for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx: Remove unused and unconfigured memory test code.Kumar Gala
Remove unused and unconfigured DDR test code from FSL 85xx boards. Besides, other common code exists. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Convert MPC8540/MPC8560 ADS to new TLB setupKumar Gala
2008-01-1685xx: convert MPC8540/MPC8560 ADS over to use new LAW init codeKumar Gala
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Update Freescale MPC85xx ADS/CDS/MDS board configKumar Gala
* Enabled CONFIG_CMD_ELF Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
* Removed some misc environment setup * Enabled CONFIG_CMDLINE_EDITING Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Update MPC8560 ADS to use libfdtKumar Gala
Updated the MPC8560 ADS config to use libfdt and assume use of aliases for ethernet, pci, and serial for the various fixups that are done. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-03Merge branch 'testing' into workingAndy Fleming
Conflicts: CHANGELOG fs/fat/fat.c include/configs/MPC8560ADS.h include/configs/pcs440ep.h net/eth.c
2007-07-11Polished the 85xx ADS config filesAndy Fleming
Made the boot commands use device trees by default. Also moved the ramdisk to 1000000 (I think the previous address was getting overridden during boot). Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-07-11Add support for CPM device tree configuration to 8560 ADSAndy Fleming
* Adds code to modify CPM frequencies * Cleans up the config file to #define TSEC and (for now) #undef FCC * Adds the MII command for all 8560 ADS configurations * Updates config file to provide convenience commands for booting with a device tree Signed-off-by: Vitaly Bordug <vbordug@ru.mvista.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-07-10include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
