path: root/include/configs/MPC8548CDS.h
2007-10-19Improve handling of PCI interrupt device tree fixup on MPC85xx CDSKumar Gala
On the MPC85xx CDS we have two issues: 1. The device tree fixup code did not check to see if the property we are trying to update is actually found. Its possible that it would update random memory starting at 0. 2. Newer Linux kernel's have moved the location of the PCI nodes to be sibilings of the soc node and not children. The explicit PATH to the PCI node would not be found for these device trees. Add the ability to handle both paths. In the future we shouldn't handle such fixups by explicit path. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-298548cds fixesEd Swarthout
Restore CONFIG_EXTRA_ENV_SETTINGS definition which contains the correct consoledev needed for linux boot. Standardize on fdt{file,addr} var to hold dtb file name. Set PCI inbound memory region from CFG_MEMORY_{BUS,PHYS}. Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-1485xxCDS: Add make targets for legacy systems.Randy Vinson
The PCI ID select values on the Arcadia main board differ depending on the version of the hardware. The standard configuration supports Rev 3.1. The legacy target supports Rev 2.x. Signed-off-by Randy Vinson <rvinson@mvista.com>
2007-08-14Fix minor 85xx warningsAndy Fleming
Some patches had inserted warnings into the build: * mpc8560ads declared data without using it * cpu_init declared ecm and immap without using it in all CONFIGs * MPC8548CDS.h had its default filenames changed so that they contained "\m" in the paths. Made the defaults not Windows-specific (or anything-specific) Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-148548cds PCIE support.Ed Swarthout
Make the early L1 cache stack region guarded to prevent speculative fetches outside the locked range. Use _PHYS defines, not _MEM for cpu-side PCI memory mapped regions. init.S whitespace cleanup. Allow TEXT_BASE value to be specified on command line. This allows it to be set to 0xfffc0000 which cuts the uboot binary in half. Clear and enable lbc and ecm errors. Update last_busno in device-tree for pci and pcie. Remove load of obsolete cpu/mpc85xx/pci.0 Signed-off-by: Ed Swarthout <Ed.Swarthout@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2007-07-10include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-05-02Cleaned up some 85xx PCI bugsAndy Fleming
* Cleaned up the CDS PCI Config Tables and added NULL entries to the end * Fixed PCIe LAWBAR assignemt to use the cpu-relative address * Fixed 85xx PCI code to assign powar region sizes based on the config values (rather than hard-coding them) * Fixed the 8548 CDS PCI2 IO to once again have 0 as the base address Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-04-23Fix PCI I/O space mapping on Freescale MPC85x0ADSSergei Shtylyov
The PCI I/O space mapping for Freescale MPC8540ADS board was broken by commit 52c7a68b8d587ebcf5a6b051b58b3d3ffa377ddc which failed to update the #define's describing the local address window used for the PCI I/O space accesses -- fix this and carry over the necessary changes into the MPC8560ADS code since the PCI I/O space mapping was also broken for this board (by the earlier commit 087454609e47295443af793a282cddcd91a5f49c). Add the comments clarifying how the PCI I/O space must be mapped to all the MPC85xx board config. headers. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> board/mpc8540ads/init.S | 4 ++-- board/mpc8560ads/init.S | 4 ++-- include/configs/MPC8540ADS.h | 5 ++--- include/configs/MPC8541CDS.h | 2 +- include/configs/MPC8548CDS.h | 2 +- include/configs/MPC8560ADS.h | 8 ++++---- 6 files changed, 12 insertions(+), 13 deletions(-)
2007-04-23u-boot: Disables MPC8548CDS 2T_TIMING for DDR by defaultebony.zhu@freescale.com
This patch disables MPC8548CDS 2T_TIMING for DDR by default. Signed-off-by:Ebony Zhu <ebony.zhu@freescale.com>
2007-04-23u-boot: Enable PCI function and add PEX & rapidio memory map on MPC8548CDS boardZang Roy-r61911
Enable PCI function and add PEX & rapidio memory map on MPC8548CDS board. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
2006-10-24Merge with /home/wd/git/u-boot/masterWolfgang Denk
(Conflicts between Jon Loeliger's and Matthew McClintock's tree were resolved by in favour of Jon's version.)
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-09-19Updated config headers to add default FDT-based bootingAndy Fleming
2006-09-19Add support for eTSEC 3 & 4 on 8548 CDSAndy Fleming
* Added support for using eTSEC 3 and eTSEC 4 on the 8548 CDS. This will only work on rev 1.3 boards (but doesn't break older boards) * Cleaned up some comments to reflect the expanded role of tsec in other systems
2006-08-09* Added VIA configuration tableMatthew McClintock
* Added support for PCI2 on CDS Patch by Andy Fleming 17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-08-09* Add Flat Dev Tree construction for MPC85xx ADS and CDS boards Patch by Jon ↵Matthew McClintock
Loeliger 17-Jan-2006 Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-06-28* Added VIA configuration tableMatthew McClintock
2006-06-28* Add Flat Dev Tree construction for MPC85xx ADS and CDS boardsMatthew McClintock
Patch by Jon Loeliger 17-Jan-2006 Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
