path: root/include/configs/MPC8548CDS.h
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-01powerpc: convert selected boards to generic board structureYork Sun
Convert MPC8540ADS, MPC8541CDS, MPC8544CDS, MPC8548CDS, MPC8555CDS, MPC8560ADS, MPC8568MDS, MPC8569MDS, MPC8610HPCD to use generic board structure. Signed-off-by: York Sun <yorksun@freescale.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-08-08powerpc/85xx: improve definition of BR_PHYS_ADDR macroTimur Tabi
The BR_PHYS_ADDR(x) macro was missing parentheses around "x" in the macro definition, so callers had to supply their own parenthesis. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2011-11-08powerpc/mpc8548cds: Fix network initializationchenhui zhao
Add board_eth_init(). PCIe network card is also supported. Put RGMII init after tsec_eth_init(). Skip initializing eTSEC3 and eTSEC4 with Carrier boards prior to ver 1.3. Signed-off-by: Ebony Zhu Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-13powerpc/mpc8548cds: Add 36-bit supportchenhui zhao
Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-13powerpc/mpc8548cds: Code cleanup and refactoringchenhui zhao
- Rework tlb and law tables. - PCI2 is not available on MPC8548CDS, so remove it. - Move the memory map to the board config file. - Rewrite the board info according to the manual. - Remove unnecessary macros and redefine some macros to align with other boards. - Fix some typos. Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-10-09powerpc/mpc8548cds: Update config filechenhui zhao
- Increase the size of malloc space. - Enable e1000 network card. - Show pci devices on startup. - Change the location of env address. - Use hwconfig to turn off ECC by default. [Kumar Gala] Fixed white space formating for CONFIG_EXTRA_ENV_SETTINGS Signed-off-by: Zhao Chenhui <chenhui.zhao@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-13powerpc/mpc8548cds: Remove incorrect DDR_MSYNC_IN erratum defineBecky Bruce
This erratum doesn't exist on this processor, and the workaround spins on a non-existent register, causing boot to hang. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Convert MPC8548CDS to use common SRIO init codeKumar Gala
2011-01-14powerpc/85xx: Rework MPC8548CDS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8548CDS board and utilize the common fsl_pcie_init_board(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-1485xx boards: Rename CONFIG_DDR_DLL to CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_INBecky Bruce
This config option is for an erratum workaround; rename it to be more clear. Also, drop it from config files don't need it and were undefining it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-08-2885xx: Remove unused CONFIG_CLEAR_LAW0 definesPeter Tyser
Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-3085xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_IO_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI IO space is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_MEM_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI memory is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
