The definitions for CONFIG_SYS_PROMPT are varied with little reason other
than to display the board name. Over half the definitions are "==> ", so
make this the default. The rest of the boards remain unchanged to avoid
breaking any external scripts expecting a certain prompt.
Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
libata already has similar functions as implemented in the ahci code.
Refactor the code to use the libata variants and remove the dependency on
ata.h. Convert some defines to use the version from libata.h. Also, remove
some unnecessary memset's of bss data.
This is a step toward hopefully merging ahci.c and dw_ahsata.c which are
essentially the same driver.
Reviewed-by: Tom Rini <trini@ti.com>
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to fsl_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
- added to soft_i2c driver new multibus/multiadpater support
The pci_indirect.c file is always compiled when
CONFIG_PCI is defined although the indirect PCI
bridge support is not needed by every board.
Introduce a new CONFIG_PCI_INDIRECT_BRIDGE
config option and only compile indirect PCI
bridge support if this options is enabled.
Also add the new option into the configuration
files of the boards which needs that.
Compile tested for powerpc, x86, arm and nds32.
MAKEALL results:
powerpc:
--------------------- SUMMARY ----------------------------
Boards compiled: 641
Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB )
Note: the warnings for ELPPC and MPC8323ERDB are present even
without the actual patch.
x86:
Boards compiled: 1
arm:
Boards compiled: 311
nds32:
Boards compiled: 3
Cc: Tom Rini <trini@ti.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
USB controller in uboot is a required feature for MPC8544DS. Without this
support there is no 'usb' command in uboot.
Signed-off-by: Jia Hongtao <B38951@freescale.com>
Signed-off-by: Li Yang <leoli@freescale.com>
Signed-off-by: Andy Fleming <afleming@freescale.com>
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals.
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals.
Now that none of the core checks CONFIG_NET_MULTI, there's not much point
in boards defining it. So scrub all references to it.
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW
macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS.
This is necessary for the assembly-language code that relocates CCSR, since
the assembler does not understand 64-bit constants.
CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the
CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it
should not be defined in a board header file. Similarly,
CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so
it should also not be defined in the board header file.
CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that
CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT,
and so CCSR will not be relocated.
Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot
builds (e.g. NAND) are required to relocate CCSR only during the last stage
(i.e. the "real" U-Boot). All other stages should define
CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated.
README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros.
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we
should also allow the kernel image to be up to 64M decompressed. This
also matches what we pass to the OS based on the ePAPR specification.
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we
should also allow the kernel image to be up to 16M decompressed.
Remove duplicated code in MPC8544DS board and utilize the common
fsl_pcie_init_ctrl(). We also now dynamically setup the LAWs for PCI
controllers based on which PCIe controllers are enabled.
We don't use the full fsl_pcie_init_ctrl() since we have to handle PCIE3
specially to setup the additional memory map region and we utilize a
single LAW to cover the controller.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
because it's convenient.
Remove dupliacted setting of PCI/PCIe address and offsets in board
config.h.
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs.
Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
There is more and more usage of printing 64bit values,
so enable this feature generally, and delete the
CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL
defines.
A bunch of the 85xx boards have this cruft in them - it's not used
anywhere. Delete it.
For some reason the MPC8544 enabled BEDBUG if PCI was enabled and that
got copied int the MPC8536, MPC8572 and P2020 DS boards. The BEDBUG
support has never been made to work completely on e500/85xx so we
just disable it to save space and match the other FSL 85xx boards.
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of
swizzling the upper address bits of the NOR flash we boot out of which
creates the concept of "virtual" banks. This is useful in that we can
flash a test of image of u-boot and reset to one of the virtual banks
while still maintaining a working image in "bank 0".
The PIXIS FPGA exposes registers on LBC which we can use to determine
which "bank" we are booting out of (as well as setting which bank to
boot out of).
We have always mapped at least 16M in the kernel and we have seen cases
with new kernel features that a kernel image needs more than 8M of
memory.
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet
driver, but the code that used that macro was removed over a year
ago, so board configuration files no longer need to define it.
The _IO_BASE macro is also automatically defined to 0 if it isn't
already set, so there's no need to define that macro either in the
board configuration files.
Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Acked-by: Andy Fleming <afleming@freescale.com>
Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de>
Acked-by: Kim Phillips <kim.phillips@freescale.com>
Introduce a new define to seperate out the virtual address that PCI
IO space is at from the physical address. In most situations these are
mapped 1:1. However any code accessing the bus should use VIRT.
memory is at from the physical address. In most situations these are
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead
of _IO_BASE so we are more explicit.
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead
of _MEM_BASE so we are more explicit.
Prevent further viral propogation of the unused
symbol CONFIG_L1_INIT_RAM by just removing it.
The DDR controller of 8548/8544/8568/8572/8536 processors
have the ECC data init feature, and the new DDR code is
using the feature, and we don't need the way with DMA to
init memory any more.
Signed-off-by: Dave Liu <daveliu@freescale.com>
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS,
MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows()
and ft_fsl_pci_setup().
With these changes the board code is a bit smaller and we get dma-ranges
set in the device tree for these boards.
Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
The pixis sgmii command depend on the FPGA support on the board, some 85xx
boards support SGMII riser card but did not support this command, define
CONFIG_PIXIS_SGMII_CMD for those boards which support the sgmii command.
Not like 8544, 8572 has 4 eTsec so that the other two's pixis bits
are not supported by 8544. Therefor, define PIXIS_VSPEED2_MASK and
PIXIS_VCFGEN1_MASK in header file for both boards.
Signed-off-by: Liu Yu <yu.liu@freescale.com>
The 8544DS and 8572DS platforms support an optional SGMII riser card to
expose ethernet over an SGMII interface. Once the card is in, it is also
necessary to configure the board such that it uses the card, rather than
the on-board ethernet ports. This can either be done by flipping dip switches
on the motherboard, or by modifying registers in the pixis. Either way
requires a reboot.
This adds a command to allow users to choose which ports are routed through
the SGMII card, and which through the onboard ports. It also allows users
to revert to the current switch settings.
This code does not work on the 8572, as the PIXIS is different.
The 8544DS and 8572DS systems have an optional SGMII riser card which
exposes new ethernet ports which are connected to the eTSECs via an
SGMII interface. The SGMII PHYs for this board are offset from the standard
PHY addresses, so this code modifies the passed in tsec_info structure to
use the SGMII PHYs on the card, instead.
