path: root/include/configs/MPC8544DS.h
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29powerpc/85xx: introduce and document CONFIG_SYS_CCSRBAR macrosTimur Tabi
Introduce the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, which contain the high and low portions of CONFIG_SYS_CCSRBAR_PHYS. This is necessary for the assembly-language code that relocates CCSR, since the assembler does not understand 64-bit constants. CONFIG_SYS_CCSRBAR_PHYS is automatically defined from the CONFIG_SYS_CCSRBAR_PHYS_HIGH and CONFIG_SYS_CCSRBAR_PHYS_LOW macros, so it should not be defined in a board header file. Similarly, CONFIG_SYS_CCSRBAR_DEFAULT is defined for each SOC in config_mpc85xx.h, so it should also not be defined in the board header file. CONFIG_SYS_CCSR_DO_NOT_RELOCATE is a "short-cut" macro that guarantees that CONFIG_SYS_CCSRBAR_PHYS is set to the same value as CONFIG_SYS_CCSRBAR_DEFAULT, and so CCSR will not be relocated. Since CONFIG_SYS_CCSRBAR_DEFAULT is locked to a fixed value, multi-stage U-Boot builds (e.g. NAND) are required to relocate CCSR only during the last stage (i.e. the "real" U-Boot). All other stages should define CONFIG_SYS_CCSR_DO_NOT_RELOCATE to ensure that CCSR is not relocated. README is updated with descriptions of all the CONFIG_SYS_CCSRBAR_xxx macros. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Rework MPC8544DS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8544DS board and utilize the common fsl_pcie_init_ctrl(). We also now dynamically setup the LAWs for PCI controllers based on which PCIe controllers are enabled. We don't use the full fsl_pcie_init_ctrl() since we have to handle PCIE3 specially to setup the additional memory map region and we utilize a single LAW to cover the controller. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-08-1085xx: Removed BEDBUG support from FSL 85xx boardsKumar Gala
For some reason the MPC8544 enabled BEDBUG if PCI was enabled and that got copied int the MPC8536, MPC8572 and P2020 DS boards. The BEDBUG support has never been made to work completely on e500/85xx so we just disable it to save space and match the other FSL 85xx boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Add pci/pcie E1000 ethernet support for MPC8544DS and MPC8536 boardsRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Report which "bank" of NOR flash we are booting from on FSL boardsKumar Gala
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of swizzling the upper address bits of the NOR flash we boot out of which creates the concept of "virtual" banks. This is useful in that we can flash a test of image of u-boot and reset to one of the virtual banks while still maintaining a working image in "bank 0". The PIXIS FPGA exposes registers on LBC which we can use to determine which "bank" we are booting out of (as well as setting which bank to boot out of). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_IO_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI IO space is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_MEM_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI memory is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Convert CONFIG_SYS_PCI*_IO_BASE to _IO_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead of _IO_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Convert CONFIG_SYS_{PCI*,RIO*}_MEM_BASE to _MEM_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead of _MEM_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
2008-12-03Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-0385xx: remove the unused ddr_enable_ecc in the board fileDave Liu
The DDR controller of 8548/8544/8568/8572/8536 processors have the ECC data init feature, and the new DDR code is using the feature, and we don't need the way with DMA to init memory any more. Signed-off-by: Dave Liu <daveliu@freescale.com> Acked-by: Andy Fleming <afleming@freescale.com>
2008-10-2485xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-2485xx: Enable 64-bit PCI resources on all Freescale boardsKumar Gala
2008-10-18Make pixis_set_sgmii more general to support MPC85xx boards.Liu Yu
The pixis sgmii command depend on the FPGA support on the board, some 85xx boards support SGMII riser card but did not support this command, define CONFIG_PIXIS_SGMII_CMD for those boards which support the sgmii command. Not like 8544, 8572 has 4 eTsec so that the other two's pixis bits are not supported by 8544. Therefor, define PIXIS_VSPEED2_MASK and PIXIS_VCFGEN1_MASK in header file for both boards. Signed-off-by: Liu Yu <yu.liu@freescale.com>
2008-10-1885xx: Enable interrupt and setexpr commands on Freescale 85xx boardsKumar Gala
2008-09-02Add pixis_set_sgmii commandAndy Fleming
The 8544DS and 8572DS platforms support an optional SGMII riser card to expose ethernet over an SGMII interface. Once the card is in, it is also necessary to configure the board such that it uses the card, rather than the on-board ethernet ports. This can either be done by flipping dip switches on the motherboard, or by modifying registers in the pixis. Either way requires a reboot. This adds a command to allow users to choose which ports are routed through the SGMII card, and which through the onboard ports. It also allows users to revert to the current switch settings. This code does not work on the 8572, as the PIXIS is different. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Add support for Freescale SGMII Riser CardAndy Fleming
The 8544DS and 8572DS systems have an optional SGMII riser card which exposes new ethernet ports which are connected to the eTSECs via an SGMII interface. The SGMII PHYs for this board are offset from the standard PHY addresses, so this code modifies the passed in tsec_info structure to use the SGMII PHYs on the card, instead. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-27FSL DDR: Convert MPC8544DS to new DDR code.Kumar Gala
2008-07-14Clean up INIT_RAM optionsAndy Fleming
The L2_INIT_RAM option was unused, and recent changes to the TLB code meant that the INIT_RAM TLBs weren't being cleared out. In order to reduce the amount of mapped space attached to nothing, we change things so the TLBs get cleared. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14Remove fake flash bank from 8544 DSAndy Fleming
The fake flash bank was generating errors for anyone who didn't have a PromJET hooked up to the board. As that constitutes the vast majority of users, we remove it. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-07-14MPC8544DS: Add ATI Video card supportKumar Gala
Add support for using a PCIe ATI Video card on PCIe2. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-07-14Remove LBC_CACHE_BASE from 8544 DSAndy Fleming
The 8544 DS doesn't have any cacheable Local Bus memories set up. By mapping space for some anyway, we were allowing speculative loads into unmapped space, which would cause an exception (annoying, even if ultimately harmless). Removing LBC_CACHE_BASE, and using LBC_NONCACHE_BASE for the LBC LAW solves the problem. Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-06-1185xx: remove dummy board_early_init_fKumar Gala
A number of board ports have empty version of board_early_init_f for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-11MPC8544DS: Update config.hKumar Gala
* Enable flash progress * remove CLEAR_LAW0 since we dont really use it Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx: Remove unused and unconfigured memory test code.Kumar Gala
Remove unused and unconfigured DDR test code from FSL 85xx boards. Besides, other common code exists. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-04-26MPC8544DS: Removes the unknown flash message informationRoy Zang
This patch removes the unknown flash message information: '## Unknown FLASH on Bank 1 - Size = 0xdeadbeef = -286261248 MB' This unknown flash message is caused by PromJet. Some of the board user is unhappy with this information. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
