The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID
format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale
86xx boards already use sys_eeprom.c, so this patch migrates the remaining
Freescale 85xx boards to use it as well. cds_eeprom.c is deleted.
rename CFG_FLASH_CFI_DRIVER to CONFIG_FLASH_CFI_DRIVER
A number of board ports have empty version of board_early_init_f
for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F.
Remove unused and unconfigured DDR test code from FSL 85xx boards.
Besides, other common code exists.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Each file that can be built here now follows some
CONFIG_ option so that they are appropriately built
or not, as needed. And CONFIG_ defines were added
to various board config files to make sure that happens.
The other board/freescale/*/Makefiles no longer need
to reach up and over into ../common to build their
individually needed files any more.
Boards that are CDS specific were renamed with cds_ prefix.
When we go to 36-bit physical addresses we need to keep the concept of
the physical CCSRBAR address seperate from the virtual one.
For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR
Now that all boards have been converted, remove old config code and the
config option for the new style.
Either use the standard defines in asm/cache.h or grab the information
at runtime from the L1CFG SPR.
Also, minor cleanup in cache.h to make the code a bit more readable.
* Enabled CONFIG_CMD_ELF
* Removed some misc environment setup
* Enabled CONFIG_CMDLINE_EDITING
Updated the MPC85xx CDS config to use libfdt and assume use of aliases for
ethernet, pci, and serial for the various fixups that are done.
On the MPC85xx CDS we have two issues:
1. The device tree fixup code did not check to see if the property we are
trying to update is actually found. Its possible that it would update
random memory starting at 0.
2. Newer Linux kernel's have moved the location of the PCI nodes to be
sibilings of the soc node and not children. The explicit PATH to the PCI
node would not be found for these device trees. Add the ability to handle
both paths. In the future we shouldn't handle such fixups by explicit path.
and make some minor corrections to the FDT part of the README.
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether
to update TSEC1's device-tree node, so we need to add it
to all the boards with TSECs. Do this for 83xx and 86xx, too,
since they will eventually do something similar.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The tsec_info structure and array has a "flags" field for each
ethernet controller. This field is the only reason there are
settings. Switch to defining TSECn_FLAGS for each controller
in the config header, and we can greatly simplify the array, and
also simplify the addition of future boards.
The PCI ID select values on the Arcadia main board differ depending
on the version of the hardware. The standard configuration supports
Rev 3.1. The legacy target supports Rev 2.x.
Signed-off-by Randy Vinson <rvinson@mvista.com>
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
For all practical u-boot purposes, TSECs don't differ throughout the
mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx.
The PCI I/O space mapping for Freescale MPC8540ADS board was broken by commit
52c7a68b8d587ebcf5a6b051b58b3d3ffa377ddc which failed to update the #define's
describing the local address window used for the PCI I/O space accesses -- fix
this and carry over the necessary changes into the MPC8560ADS code since the
PCI I/O space mapping was also broken for this board (by the earlier commit
087454609e47295443af793a282cddcd91a5f49c). Add the comments clarifying how
the PCI I/O space must be mapped to all the MPC85xx board config. headers.
board/mpc8540ads/init.S | 4 ++--
board/mpc8560ads/init.S | 4 ++--
include/configs/MPC8540ADS.h | 5 ++---
include/configs/MPC8541CDS.h | 2 +-
include/configs/MPC8548CDS.h | 2 +-
include/configs/MPC8560ADS.h | 8 ++++----
6 files changed, 12 insertions(+), 13 deletions(-)
Introduced COFIG_FSL_I2C to select the common FSL I2C driver.
And removed hard i2c path from a few u-boot.lds scipts too.
Minor whitespace cleanups along the way.
* Added support for PCI2 on CDS
Patch by Andy Fleming 17-Mar-2006
Loeliger 17-Jan-2006
Implemented support for MPC8548CDS board.
Added DDR II support based on SPD values for MPC85xx boards.
This roll-up patch also includes bugfies for the previously
published patches:
DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
For MPC85xxCDS:
Adds Relaxed Timing TRLX bit to FLASH ORx regs to allow
for faster flash parts.
Add documentation for BR/OR for FLASH.
- Convert the CPM2 based functionality to use new CONFIG_CPM2
option rather than a myriad of CONFIG_MPC8560-like variants.
Applies to MPC85xx and MPC8260 boards, includes stxgp3 and sbc8560.
Eliminates the CONFIG_MPC8560 option entirely. Distributes the
new CONFIG_CPM2 option to each 8260 board.
Reset monitor size back to 256 so environment can be written
to flash on MPC85xx ADS and CDS releases.
* Patch by Paolo Broggini, 02 Sep 2004:
Make BSS clearing on ARM systems more robust
* Patch by Yue Hu and Joe, 01 Sep 2004:
- add PCI support for ixp425;
- add EEPRO100 suppor tfor ixdp425 board.
* Fix problem with protected sector detection in driver/cfi_flash.c
* Cleanup confusing use of CONFIG_ETH*ADDR - ust his only to
pre-define a MAC address; use CONFIG_HAS_ETH* to enable support for
additional ethernet addresses.
* Cleanup drivers/i82365.c - avoid duplication of code
* Fix bogus "cannot span across banks" flash error message
* Add support for CompactFlash for the CPC45 Board.
- Add support for Altera Nios-II processors.
- Add support for Psyent PCI-5441 board.
- Add support for Psyent PK1C20 board.
- Add support for the MPC8541 and MPC8555 CDS boards
- Cleanup eth?addr handling: make dependent on CONFIG_ETH?ADDR
