path: root/include/configs/MPC8541CDS.h
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-03-3085xx: Use common LSDMR defines from asm/fsl_lbc.hKumar Gala
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_IO_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI IO space is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_MEM_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI memory is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Convert CONFIG_SYS_PCI*_IO_BASE to _IO_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead of _IO_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Convert CONFIG_SYS_{PCI*,RIO*}_MEM_BASE to _MEM_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead of _MEM_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
2008-12-01Removed unused CONFIG_L1_INIT_RAM symbol.Jon Loeliger
Prevent further viral propogation of the unused symbol CONFIG_L1_INIT_RAM by just removing it. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-10-2485xx: Enable 64-bit PCI resources on all Freescale boardsKumar Gala
Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-1885xx: Enable interrupt and setexpr commands on Freescale 85xx boardsKumar Gala
2008-09-09Update Freescale 85xx boards to sys_eeprom.cTimur Tabi
The new sys_eeprom.c supports both the old CCID EEPROM format and the new NXID format, and so it obsoletes board/freescale/common/cds_eeprom.c. Freescale 86xx boards already use sys_eeprom.c, so this patch migrates the remaining Freescale 85xx boards to use it as well. cds_eeprom.c is deleted. Signed-off-by: Timur Tabi <timur@freescale.com>
2008-08-27FSL DDR: Convert MPC8541CDS to new DDR code.Jon Loeliger
Signed-off-by: Jon Loeliger <jdl@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx: remove dummy board_early_init_fKumar Gala
A number of board ports have empty version of board_early_init_f for no reason since we control its via CONFIG_BOARD_EARLY_INIT_F. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-06-1185xx: Remove unused and unconfigured memory test code.Kumar Gala
Remove unused and unconfigured DDR test code from FSL 85xx boards. Besides, other common code exists. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-03-26FSL: Clean up board/freescale/common/MakefileJon Loeliger
Each file that can be built here now follows some CONFIG_ option so that they are appropriately built or not, as needed. And CONFIG_ defines were added to various board config files to make sure that happens. The other board/freescale/*/Makefiles no longer need to reach up and over into ../common to build their individually needed files any more. Boards that are CDS specific were renamed with cds_ prefix. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2008-03-2685xx: Add the concept of CFG_CCSRBAR_PHYSKumar Gala
When we go to 36-bit physical addresses we need to keep the concept of the physical CCSRBAR address seperate from the virtual one. For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Get ride of old TLB setup codeKumar Gala
Now that all boards have been converted, remove old config code and the config option for the new style. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-01-1785xx: Convert MPC8541/MPC8555/MPC8548 CDS to new TLB setupKumar Gala
2008-01-1685xx: convert MPC8541/MPC8555/MPC8548 CDS over to use new LAW init codeKumar Gala
2008-01-0985xx: Remove cache config from configs.hKumar Gala
Either use the standard defines in asm/cache.h or grab the information at runtime from the L1CFG SPR. Also, minor cleanup in cache.h to make the code a bit more readable. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Update Freescale MPC85xx ADS/CDS/MDS board configKumar Gala
* Enabled CONFIG_CMD_ELF Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
* Removed some misc environment setup * Enabled CONFIG_CMDLINE_EDITING Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-12-11Update MPC85xx CDS to use libfdtKumar Gala
Updated the MPC85xx CDS config to use libfdt and assume use of aliases for ethernet, pci, and serial for the various fixups that are done. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-10-19Improve handling of PCI interrupt device tree fixup on MPC85xx CDSKumar Gala
On the MPC85xx CDS we have two issues: 1. The device tree fixup code did not check to see if the property we are trying to update is actually found. Its possible that it would update random memory starting at 0. 2. Newer Linux kernel's have moved the location of the PCI nodes to be sibilings of the soc node and not children. The explicit PATH to the PCI node would not be found for these device trees. Add the ability to handle both paths. In the future we shouldn't handle such fixups by explicit path. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-08-16Add CONFIG_HAS_ETH0 to all boards with TSECAndy Fleming
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether to update TSEC1's device-tree node, so we need to add it to all the boards with TSECs. Do this for 83xx and 86xx, too, since they will eventually do something similar. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-16Define tsec flag values in config filesAndy Fleming
The tsec_info structure and array has a "flags" field for each ethernet controller. This field is the only reason there are settings. Switch to defining TSECn_FLAGS for each controller in the config header, and we can greatly simplify the array, and also simplify the addition of future boards. Signed-off-by: Andy Fleming <afleming@freescale.com>
2007-08-1485xxCDS: Add make targets for legacy systems.Randy Vinson
The PCI ID select values on the Arcadia main board differ depending on the version of the hardware. The standard configuration supports Rev 3.1. The legacy target supports Rev 2.x. Signed-off-by Randy Vinson <rvinson@mvista.com>
2007-07-10include/configs/[J-O]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in 85xx board config files.Jon Loeliger
2007-05-17Reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECxKim Phillips
For all practical u-boot purposes, TSECs don't differ throughout the mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-04-23Fix PCI I/O space mapping on Freescale MPC85x0ADSSergei Shtylyov
The PCI I/O space mapping for Freescale MPC8540ADS board was broken by commit 52c7a68b8d587ebcf5a6b051b58b3d3ffa377ddc which failed to update the #define's describing the local address window used for the PCI I/O space accesses -- fix this and carry over the necessary changes into the MPC8560ADS code since the PCI I/O space mapping was also broken for this board (by the earlier commit 087454609e47295443af793a282cddcd91a5f49c). Add the comments clarifying how the PCI I/O space must be mapped to all the MPC85xx board config. headers. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> board/mpc8540ads/init.S | 4 ++-- board/mpc8560ads/init.S | 4 ++-- include/configs/MPC8540ADS.h | 5 ++--- include/configs/MPC8541CDS.h | 2 +- include/configs/MPC8548CDS.h | 2 +- include/configs/MPC8560ADS.h | 8 ++++---- 6 files changed, 12 insertions(+), 13 deletions(-)
2006-10-20Converted all 85xx boards to use a common FSL I2C driver.Jon Loeliger
Introduced COFIG_FSL_I2C to select the common FSL I2C driver. And removed hard i2c path from a few u-boot.lds scipts too. Minor whitespace cleanups along the way. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2006-09-19Updated config headers to add default FDT-based bootingAndy Fleming
2006-08-09* Added VIA configuration tableMatthew McClintock
* Added support for PCI2 on CDS Patch by Andy Fleming 17-Mar-2006 Signed-off-by: Andy Fleming <afleming@freescale.com>
2006-08-09* Add Flat Dev Tree construction for MPC85xx ADS and CDS boards Patch by Jon ↵Matthew McClintock
Loeliger 17-Jan-2006 Signed-off-by: Jon Loeliger <jdl@freescale.com>
2005-07-25* Patch by Jon Loeliger, 2005-05-05Jon Loeliger
Implemented support for MPC8548CDS board. Added DDR II support based on SPD values for MPC85xx boards. This roll-up patch also includes bugfies for the previously published patches: DDRII CPO, pre eTSEC, 8548 LBIU, Andy's TSEC, eTSEC 3&4 I/O
