path: root/include/configs/MPC8541CDS.h
2019-03-03configs: fsl: move DDR specific defines to KconfigRajesh Bhagat
Moves below DDR specific defines to Kconfig: CONFIG_FSL_DDR_BIST CONFIG_FSL_DDR_FIRST_SLOT_QUAD_CAPABLE CONFIG_FSL_DDR_INTERACTIVE CONFIG_FSL_DDR_SYNC_REFRESH Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com> Reviewed-by: York Sun <york.sun@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove numerous CONFIG_SYS_BARGSIZE definitionsThomas Petazzoni
This commit removes definitions of CONFIG_SYS_BARGSIZE defined to be equal to CONFIG_SYS_CBSIZE in numerous configuration files. We remove such definitions in two situations: - CONFIG_SYS_CBSIZE is otherwise not defined in the board configuration file, which means the default value of CONFIG_SYS_CBSIZE == 256 applies. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common/image.c) is suitable, as it is larger. - CONFIG_SYS_CBSIZE is defined in the board configuration file, but to a value equal or less than 512. In this case, the default value of CONFIG_SYS_BARGSIZE == 512 (common.image.c) is suitable, as it is equal or larger. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: remove CONFIG_SYS_CBSIZE when the default value is usedThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_CBSIZE, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Drop <config.h> from stih410-b2260.h] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11Convert CONFIG_CMD_REGINFO to KconfigChristophe Leroy
This patch converts CONFIG_CMD_REGINFO to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Convert CONFIG_CMD_IRQ to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_IRQ Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-04ddr: fsl: Move macro CONFIG_NUM_DDR_CONTROLLERS to KconfigYork Sun
Use option NUM_DDR_CONTROLLERS in ddr Kconfig and clean up existing usage in ls102xa and fsl-layerscape. Remove all powerpc macros in config header and board header files. Signed-off-by: York Sun <york.sun@nxp.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-04powerpc: E500: Move CONFIG_E500 and CONFIG_E500MC to KconfigYork Sun
Use Kconfig option for E500 and E500MC macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-12-02powerpc: mpc85xx: Move CONFIG_FSL_LAW to KconfigYork Sun
Some header files have this macro defined conditionally and redefined unconditionally. Remove all existing definitions. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: MPC8541CDS: Remove macro CONFIG_MPC8541CDSYork Sun
Replace with CONFIG_TARGET_MPC8541CDS from Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: mpc8541: Remove macro CONFIG_MPC8541York Sun
Replace CONFIG_MPC8541 with ARCH_MPC8541 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-21cmd: Convert CONFIG_CMD_ELF to KconfigBin Meng
Convert CONFIG_CMD_ELF to Kconfig and tidy up affected boards. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-09-01powerpc: convert selected boards to generic board structureYork Sun
Convert MPC8540ADS, MPC8541CDS, MPC8544CDS, MPC8548CDS, MPC8555CDS, MPC8560ADS, MPC8568MDS, MPC8569MDS, MPC8610HPCD to use generic board structure. Signed-off-by: York Sun <yorksun@freescale.com>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-01-24powerpc: mpc85xx: move CONFIG_MPC85xx definition to CPU config.mkMasahiro Yamada
Define CONFIG_MPC85xx in arch/powerpc/cpu/mpc85xx/config.mk because all target boards with mpc85xx cpu define it. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-13kgdb: configs: remove obsolete CONFIG_KGDB_SER_INDEXVladimir Zapolskiy
The last users of CONFIG_KGDB_SER_INDEX were removed more than 3 years ago in commits 550650ddd0 and bf16500f79, either kgdb subsystem should care about this parameter or it should be gone completely. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
2013-11-25Driver/DDR: Moving Freescale DDR driver to a common driverYork Sun
Freescale DDR driver has been used for mpc83xx, mpc85xx, mpc86xx SoCs. The similar DDR controllers will be used for ARM-based SoCs. Signed-off-by: York Sun <yorksun@freescale.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 1/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs A-Z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
