The MPC8540EVAL board is no longer maintained and thus we are removing
support for it.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Now that warm booting is not supported, there isn't a need for the
BOOTFLAG_COLD and BOOTFLAG_WARM defines, so remove them.
Note that this change makes the board info bd_bootflags field useless.
It will always be set to 0, but we leave it around so that we don't
break the board info structure that some OSes are expecting to be passed
from U-Boot.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs.
Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
The CONFIG_CMD_ENV option controls enablement of the `saveenv` command
rather than a generic "env" command, or anything else related to the
environment. So, let's make sure the define is named accordingly.
Prevent further viral propogation of the unused
symbol CONFIG_L1_INIT_RAM by just removing it.
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
When we go to 36-bit physical addresses we need to keep the concept of
the physical CCSRBAR address seperate from the virtual one.
For the majority of boards CFG_CCSBAR_PHYS == CFG_CCSRBAR
Now that all boards have been converted, remove old config code and the
config option for the new style.
Converted ATUM8548, MPC8568 MDS, MPC8540 EVAL, and TQM85xx boards over
to use new LAW init code.
Either use the standard defines in asm/cache.h or grab the information
at runtime from the L1CFG SPR.
Also, minor cleanup in cache.h to make the code a bit more readable.
The 85xx code now relies on CONFIG_HAS_ETH0 to determine whether
to update TSEC1's device-tree node, so we need to add it
to all the boards with TSECs. Do this for 83xx and 86xx, too,
since they will eventually do something similar.
Signed-off-by: Andy Fleming <afleming@freescale.com>
The tsec_info structure and array has a "flags" field for each
ethernet controller. This field is the only reason there are
settings. Switch to defining TSECn_FLAGS for each controller
in the config header, and we can greatly simplify the array, and
also simplify the addition of future boards.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
For all practical u-boot purposes, TSECs don't differ throughout the
mpc8[356]xx families; reduce CONFIG_MPC8YXX_TSECx to CONFIG_TSECx.
Introduced COFIG_FSL_I2C to select the common FSL I2C driver.
And removed hard i2c path from a few u-boot.lds scipts too.
Minor whitespace cleanups along the way.
- C++ comments
- Trailing white space
- Indentation not by TAB
- Excessive amount of empty lines
- Trailing empty lines
Add Xianghua Xiao and Lunsheng Wang's support for the
GDA MPC8540 EVAL board.
