path: root/include/configs/MPC8536DS.h
2011-04-29powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 64M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 64M on these boards for some time so we should also allow the kernel image to be up to 64M decompressed. This also matches what we pass to the OS based on the ePAPR specification. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-08powerpc/85xx: rename NAND prefixes to CONFIG_SYSMatthew McClintock
renaming 85xx define CONFIG_NAND_OR_PRELIM to CONFIG_SYS_NAND_OR_PRELIM and CONFIG_NAND_BR_PRELIM to CONFIG_SYS_NAND_BR_PRELIM to use the more appropriate CONFIG_SYS prefix as well as be consistent with 83xx. Signed-off-by: Matthew McClintock <msm@freescale.com> cc: Scott Wood <scottwood@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-04-04powerpc/85xx: Remove config.mk for nand linker scriptKumar Gala
Move the include of mpc85xx/u-boot-nand.lds to utilize CONFIG_SYS_LDSCRIPT rather than having an explicit config.mk Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-03-06powerpc/85xx: Fix pixis_reset altbank mask on MPC8536DSMatthew McClintock
Currently, pixis_reset altbank does not work properly. This patch uses the correct mask to boot into the alternate bank. Signed-off-by: Matthew McClintock <msm@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-19powerpc/85xx: Move RESET_VECTOR_ADDRESS into config.hKumar Gala
Rather than defining it config.mk we can set it in config.h and remove config.mk from several boards that don't need it. We mimic what 4xx does and introduce CONFIG_RESET_VECTOR_ADDRESS for config.h to set. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de>
2011-01-14powerpc/85xx: Bump up the CONFIG_SYS_BOOTM_LEN to 16M on FSL 85xx boardsKumar Gala
CONFIG_SYS_BOOTMAPSZ has been 16M on these boards for some time so we should also allow the kernel image to be up to 16M decompressed. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Rework MPC8536DS pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in MPC8536DS board and utilize the common fsl_pcie_init_board(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-1485xx boards: Rename CONFIG_DDR_DLL to CONFIG_SYS_FSL_ERRATUM_DDR_MSYNC_INBecky Bruce
This config option is for an erratum workaround; rename it to be more clear. Also, drop it from config files don't need it and were undefining it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Replace CONFIG_SYS_HAS_SERDES with a weak functionKumar Gala
Instead of a #define use a null weak function for fsl_serdes_init Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-30powerpc/85xx: Introduce CONFIG_SYS_EXTRA_ENV_RELOCKumar Gala
Some systems need to relocate the env_addr pointer early because the location it points to will get invalidated before env_relocate is called. One example is on systems that might use a L2 or L3 cache in SRAM mode and initialize that cache from SRAM mode back to being a cache in cpu_init_r. We set this on the 85xx boards that have support for NAND, SPI, or SDHC/MMC boot support as they use a secondary cache in SRAM mode and need the env_addr pointer relocated since we change from SRAM to normal cache mode in cpu_init_r. Also removed CONFIG_SYS_SPL as its not used anywhere. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-11-12powerpc/85xx: add CONFIG_SYS_TEXT_BASE_SPL for 85xx nand spl buildHaiying Wang
Introduce a SPL specific CONFIG_SYS_TEXT_BASE_SPL define to be used by the linker. This has similiar semantics to CONFIG_SYS_TEXT_BASE however since SPL is a unqiue image we introduce a new variable to control its text base address. Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18mkconfig: change CONFIG_MK_ prefix into plain CONFIG_Wolfgang Denk
When planning for more generalization and Makefile cleanup it became obvious that the introduction of a separate CONFIG_MK_ name space for config options that were set through scripting in the Makefile was not a good idea. Originally the idea was to provide a script-free approach to supply configuration options - there was no real need for a separate name space. But when we now convert the existing Makefile entries to make use of this approach, it would mean that we have to touch a large number of board config files and add #ifdef / #define sequences to "convert" from the CONFIG_MK_ to the CONFIG_ name space. It seems much cleaner to get rid of this somewhat arbitrary _MK string now for the few boards that actually use it. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-08-01powerpc/85xx: configure autocompletion supportKim Phillips
because it's convenient. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-21powerpc/85xx: Rework MPC8536 SERDES is_serdes_configured supportKumar Gala
Move serdes init until after we are in ram so we can keep track of a global static protocal map for the particular serdes config we are in. This makes is_serdes_configured() much simplier and not constantly reading registers to determine if a given device is enabled based on the protocol. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-20powerpc/85xx: Move PCI/PCIe address defines into common immap_85xx.hKumar Gala
Remove dupliacted setting of PCI/PCIe address and offsets in board config.h. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-16ppc/85xx: Convert MPC8536DS to using board common ICS307 codeKumar Gala
2010-07-16mpc85xx: Add reginfo commandBecky Bruce
The new command dumps the TLBCAM, the LAWs, and the BR/OR regs. Add CONFIG_CMD_REGINFO to the config for all MPC85xx parts. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-07ppc/85xx: Use CONFIG_NS16550_MIN_FUNCTIONS to reduce NAND_SPL sizeKumar Gala
The MPC8536DS_NAND SPL build was failing due to code size increase introduced by commit: commit 33f57bd553edf29dffef5a6c7d76e169c79a6049 Author: Kumar Gala <galak@kernel.crashing.org> Date: Fri Mar 26 15:14:43 2010 -0500 85xx: Fix enabling of L1 cache parity on secondary cores We built in some NS16550 functions that we dont need and can get rid of them via CONFIG_NS16550_MIN_FUNCTIONS. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-08common: delete CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOULHeiko Schocher
There is more and more usage of printing 64bit values, so enable this feature generally, and delete the CONFIG_SYS_64BIT_VSPRINTF and CONFIG_SYS_64BIT_STRTOUL defines. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-12-0285xx: Remove unused CONFIG_ASSUME_AMD_FLASH from config filesBecky Bruce
A bunch of the 85xx boards have this cruft in them - it's not used anywhere. Delete it. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
2009-09-30On-chip ROM boot: MPC8536DS supportMingkai Hu
The MPC8536E is capable of booting from the on-chip ROM - boot from eSDHC and boot from eSPI. When power on, the porcessor excutes the ROM code to initialize the eSPI/eSDHC controller, and loads the mian U-Boot image from the memory device that interfaced to the controller, such as the SDCard or SPI EEPROM, to the target memory, e.g. SDRAM or L2SRAM, then boot from it. The memory device should contain a specific data structure with control word and config word at the fixed address. The config word direct the process how to config the memory device, and the control word direct the processor where to find the image on the memory device, or where copy the main image to. The user can use any method to store the data structure to the memory device, only if store it on the assigned address. The on-chip ROM code will map the whole 4GB address space by setting entry0 in the TLB1, so the main image need to switch to Address space 1 to disable this mapping and map the address space again. This patch implements loading the mian U-Boot image into L2SRAM, so the image can configure the system memory by using SPD EEPROM. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30NAND boot: MPC8536DS supportMingkai Hu
MPC8536E can support booting from NAND flash which uses the image u-boot-nand.bin. This image contains two parts: a 4K NAND loader and a main U-Boot image. The former is appended to the latter to produce u-boot-nand.bin. The 4K NAND loader includes the corresponding nand_spl directory, along with the code twisted by CONFIG_NAND_SPL. The main U-Boot image just like a general U-Boot image except the parts that included by CONFIG_SYS_RAMBOOT. When power on, eLBC will automatically load from bank 0 the 4K NAND loader into the FCM buffer RAM where CPU can execute the boot code directly. In the first stage, the NAND loader copies itself to RAM or L2SRAM to free up the FCM buffer RAM, then loads the main image from NAND flash to RAM or L2SRAM and boot from it. This patch implements the NAND loader to load the main image into L2SRAM, so the main image can configure the RAM by using SPD EEPROM. In the first stage, the NAND loader copies itself to the second to last 4K address space, and uses the last 4K address space as the initial RAM for stack. Obviously, the size of L2SRAM shouldn't be less than the size of the image used. If so, the workaround is to generate another image that includes the code to configure the RAM by SPD and load it to L2SRAM first, then relocate the main image to RAM to boot up. Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-30mpc8536: fix board config file line lengthMingkai Hu
2009-09-24ppc/85xx: simplify the top makefile for 36-bit config for mpc8536dsMingkai Hu
2009-08-2885xx: Fix memory test range on MPC8536DSFelix Radensky
With current values of CONFIG_SYS_MEMTEST_START and CONFIG_SYS_MEMTEST_END memory test hangs if run without arguments. Set them to sane values, so that all available 512MB of RAM excluding exception vectors at the bottom and u-boot code and stack at the top can be tested. Signed-off-by: Felix Radensky <felix@embedded-sol.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Add a 36-bit physical configuration for MPC8536DSKumar Gala
We move all IO addressed (CCSR, localbus, PCI) above the 4G boundary to allow for larger memory sizes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-1085xx: Removed BEDBUG support from FSL 85xx boardsKumar Gala
For some reason the MPC8544 enabled BEDBUG if PCI was enabled and that got copied int the MPC8536, MPC8572 and P2020 DS boards. The BEDBUG support has never been made to work completely on e500/85xx so we just disable it to save space and match the other FSL 85xx boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Add pci/pcie E1000 ethernet support for MPC8544DS and MPC8536 boardsRoy Zang
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2285xx: Report which "bank" of NOR flash we are booting from on FSL boardsKumar Gala
The p2020DS, MPC8536DS, MPC8572DS, MPC8544DS boards are capable of swizzling the upper address bits of the NOR flash we boot out of which creates the concept of "virtual" banks. This is useful in that we can flash a test of image of u-boot and reset to one of the virtual banks while still maintaining a working image in "bank 0". The PIXIS FPGA exposes registers on LBC which we can use to determine which "bank" we are booting out of (as well as setting which bank to boot out of). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-2185xx: Bump up the BOOTMAP to 16M on FSL 85xx boardsKumar Gala
We have always mapped at least 16M in the kernel and we have seen cases with new kernel features that a kernel image needs more than 8M of memory. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-07-11remove _IO_BASE and KSEG1ADDR from board configuration filesTimur Tabi
The KSEG1ADDR macro used to be necessary for the RTL8139 Ethernet driver, but the code that used that macro was removed over a year ago, so board configuration files no longer need to define it. The _IO_BASE macro is also automatically defined to 0 if it isn't already set, so there's no need to define that macro either in the board configuration files. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Acked-by: Andy Fleming <afleming@freescale.com> Acked-by: Andre Schwarz <andre.schwarz@matrix-vision.de> Acked-by: Kim Phillips <kim.phillips@freescale.com>
2009-06-12mpc85xx: 8536ds: Add USB related CONFIGsVivek Mahajan
This patch adds CONFIGs for enabling USB in mpc8536ds and also adds usb_phy_type in CONFIG_EXTRA_ENV_SETTINGS. Also revamps its Copyright. Signed-off-by: Vivek Mahajan <vivek.mahajan@freescale.com> Signed-off-by: Remy Bohmer <linux@bohmer.net>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-1685xx: Add eSDHC support for 8536 DSAndy Fleming
Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Handle eLBC difference w/36-bit physicalKumar Gala
The eLBC only handles 32-bit physical address in systems with 36-bit physical. The previos generation of LBC handled 34-bit physical address in 36-bit systems. Added a new CONFIG option to convey the difference between the LBC and eLBC. Also added defines for XAM bits used in LBC for the extended 34-bit support. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Use BR_ADDR macro for NAND chipselectsKumar Gala
Use the new BR_ADDR macro to properly setup the address field of the localbus chipselects used by NAND. This allows us to deal with 36-bit phys on these boards in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_IO_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI IO space is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Introduce CONFIG_SYS_PCI*_MEM_VIRT for FSL boardsKumar Gala
Introduce a new define to seperate out the virtual address that PCI memory is at from the physical address. In most situations these are mapped 1:1. However any code accessing the bus should use VIRT. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: Convert CONFIG_SYS_PCI*_IO_BASE to _IO_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_PCI*_IO_BUS for the bus relative address instead of _IO_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-2385xx: Convert CONFIG_SYS_{PCI*,RIO*}_MEM_BASE to _MEM_BUS for FSL boardsKumar Gala
Use CONFIG_SYS_{PCI,RIO}_MEM_BUS for the bus relative address instead of _MEM_BASE so we are more explicit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: separate FLASH BASE virtual from physical addressKumar Gala
Added a CONFIG_SYS_FLASH_BASE_PHYS for use as the physical address and maintain CONFIG_SYS_FLASH_BASE as the virtual address of the flash. This allows us to deal with 36-bit phys on these boards in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-2385xx: separate PIXIS virtual from physical addressKumar Gala
Added a PIXIS_BASE_PHYS for use as the physical address and maintain PIXIS_BASE as the virtual address of the PIXIS fpga registers. This allows us to deal with 36-bit phys on these boards in the future. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Andy Fleming <afleming@freescale.com>
2009-01-23NAND: rename NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPSWolfgang Grandegger
This patch renames NAND_MAX_CHIPS to CONFIG_SYS_NAND_MAX_CHIPS and changes the default from 8 to 1 for the legacy and the new MTD NAND layer. This allows to remove all NAND_MAX_CHIPS definitions in the board config files because none of the boards use multi chip support (NAND_MAX_CHIPS > 1) so far. The bamboo and the DU440 define #define NAND_MAX_CHIPS CONFIG_SYS_MAX_NAND_DEVICE but that's bogus and did not work anyhow. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-12-14Remove unused CONFIG_ADDR_STREAMING definesPeter Tyser
