path: root/include/configs/MPC837XERDB.h
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-25mpc83xx: bump loadaddr over fdtaddr to 0x500000Kim Phillips
this seems as a good compromise between human memory, typing, and last but not least, to accommodate for current and future kernel bloat. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Dave Liu <daveliu@freescale.com>
2008-04-11mpc83xx: Fix the SATA clock setting of 837x targetsDave Liu
Currently the SATA controller clock is configured as CSB clock, usually the CSB clock is 400/333/266MHz. However, The SATA IP block is only guaranteed to operate up to 200 MHz as stated in the HW spec. The bug is reported by Joe D'Abbraccio <ljd015@freescale.com> This patch makes the SATA clock as half of CSB clock. Signed-off-by: Dave Liu <daveliu@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-28mpc83xx: enable the SATA interface on mpc8315 rdb and mpc837x rdb boardsKim Phillips
2008-03-2583xx/fdt_support: let user specifiy FSL USB Dual-Role controller roleAnton Vorontsov
Linux understands "host" (default), "peripheral" and "otg" (broken). Though, U-Boot doesn't restrict dr_mode variable to these values (think of renames in future). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-25mpc83xx: Set PCI I/O bus-address base to zero.Scott Wood
The device trees for these boards describe PCI I/O as starting from address zero from the device's perspective. Placing I/O elsewhere may cause problems with certain PCI boards, and may cause problems with Linux. Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-03-2583xx: define CONFIG_OF_STDOUT_VIA_ALIAS for the MPC837XERDB boardsAnton Vorontsov
This is primarily for the early console support. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: initialize serdes for MPC837XRDB boardsAnton Vorontsov
On the MPC8377ERDB: 2 SATA and 2 PCI-E. On the MPC8378ERDB: 2 PCI-E On the MPC8379ERDB: 4 SATA Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
2008-03-2583xx: nand support for MPC837XRDB boardsAnton Vorontsov
2008-03-2583xx: Add Vitesse VSC7385 firmware uploadingTimur Tabi
Update the MPC8349E-mITX, MPC8313E-RDB, and MPC837XE-RDB board files to upload the Vitesse VSC7385 firmware. Changed CONFIG_VSC7385 to CONFIG_VSC7385_ENET. Cleaned up the board header files to make selecting the VSC7385 easier to control. Signed-off-by: Timur Tabi <timur@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-03-07mpc83xx: make dtb basename file references equal those of linuxKim Phillips
the dts file basenames were updated in linux - this helps avoid inadvertently loading any old dtbs laying around. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2008-01-16Add support for the MPC837xERDBKim Phillips
MPC837xERDB board support includes: * DDR2 330MHz hardcoded (soldered on the board) * Local Bus NOR Flash * I2C, UART and RTC * eTSEC RGMII (TSEC0 - RTL8211B with MII; * TSEC1 - VSC7385 local bus, hardcoded, requires seperate firmware * load) Signed-off-by: Kevin Lam <kevin.lam@freescale.com> Signed-off-by: Joe D'Abbraccio <joe.d'abbraccio@freescale.com> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
